camshaft
Old Nov 3, 2006 | 12:09 AM
steve87iroc's Avatar
Car: 1987 iroc z
Engine: 355 dart platinum 215cc heads
Transmission: <<BLOWN UP TH400>>
Axle/Gears: 10 bolt 4.11's
camshaft
just have a qiuck question kinda dumb but o well i have just got a new cam for my motor i just built and just wanted to know if there will be a good sounding idle to it like the lopey sound.
Intake Duration at 050 inch Lift: 234
Exhaust Duration at 050 inch Lift: 244
Duration at 050 inch Lift: 234 int./244 exh.
Advertised Intake Duration: 292
Advertised Exhaust Duration: 302
Advertised Duration: 292 int./302 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.488 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.510 in.
Valve Lift with Factory Rocker Arm Ratio: 0.488 int./0.510 exh. lift
Lobe Separation (degrees): 114
thanks
Old Nov 3, 2006 | 12:28 AM
zz4monte's Avatar
Car: 87 Monte Carlo ss
Engine: ZZ4 1.5 rollers 650DP
Transmission: Probuilt 700-R4
Axle/Gears: 8.5 GN 3.42
I am pretty sure it will lope even with a 114 lobe seperation.Thats the edelbrock performer rpm cam. I would have tried something like the xe268 or 274.
Old Nov 3, 2006 | 02:23 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Who are you buying that cam from?
Summit/erson has it much cheaper I imagine. It'll lope and all that, the idle speed will make you smile, but it'll hurt the wallet, and lack low end, due to lazy ramp rates. All the downsides of the big cam, none of the perks of a smaller cam. The xe274 or the like would be a better cam. It sure depends on the rest of the setup though, if it'll run well or not.
Old Nov 4, 2006 | 12:04 AM
Car: 1987 iroc z
it is from summit what do you mean bu hurting the wallet.
Old Nov 4, 2006 | 12:14 AM
izcain's Avatar
Car: 1983 Camaro Z28
Engine: 584
Transmission: TSI Glide
Axle/Gears: Quick performance 9 inch
How many rpms are you shooting for? With a cam like that you will definitly need to spin it up for it to be in it's range for power. I hope you've got a nice slippy converter to go with that cam along with the correct springs.
Old Nov 4, 2006 | 12:35 AM
Car: 1987 iroc z
yes i have a turbo 400 with a 3500 stall the only problem are my sucky 882 heads. i will probley get some new ones but for now i eaither can use those heads or i have some heads that came off the 305 that was in my car which ones should i use and what needs to be done to them to work i already have the springs. thanks
Old Nov 4, 2006 | 12:44 AM
blockhead1986's Avatar
Car: 85 Firebird
Engine: Vortec 355
Transmission: Th350
he meant that summit makes the same cam, duration and lift. but it cost like 70 bucks versus $180. i got the same one and i opted to buy edelbrock, because i dint trust the summit one. looking back i wish i would have bought the summit one, or like they told me a comp cam would have been better
Old Nov 4, 2006 | 12:46 AM
Car: 1987 iroc z
yeah its a summit brand cam
Old Nov 4, 2006 | 12:54 AM
Car: 85 Firebird
Engine: Vortec 355
Transmission: Th350
i thought so because the lsa is 114 on yours and 112 on mine o well. it runs good in mine but its never been dynoed or to the track. but lookin at my setup i think it was a bad choice. well maybe you can make it work for you
Old Nov 4, 2006 | 01:35 AM
Sonix's Avatar
Car: 1982 Trans-Am
hard on the wallet - it's super lame ramp rates give you the big cam drawbacks, but none of the small cam perks. You can get your cake and eat it too, with faster ramp rates - hence, newer designed cams.
Hurting the wallet is pisspoor gas mileage.
350? 882 heads and a 234/244 cam? Nah, i'd use the 305 heads, less prone to cracking, smaller chambers, slighly better ports. You'll want all the compression you can get to use a big cam like that (remember, i'm still not suggesting you buy that cam, but for any "big" cam you want more static CR). use the 416's, and port the snot out of 'em. They work great, see sig.
Old Nov 4, 2006 | 10:10 AM
Car: 85 Firebird
Engine: Vortec 355
Transmission: Th350
hey sonix did you get your engine dynoed. and what has it done at the track just kinda curious
Old Nov 4, 2006 | 10:58 AM
Sonix's Avatar
Car: 1982 Trans-Am
no, i've been fighting tuning issues since I got it running. By the time it got all smoothed out, it was winter, and i'm back in university
In the spring i'll probably dyno tune it.
Old Nov 4, 2006 | 11:21 AM
Car: 85 Firebird
Engine: Vortec 355
Transmission: Th350
thats funny same here, my car sat 2 years no engine then back in may ordered all my parts, and built my engine. but i had to work alot to pay it off. tonight were putting it up for the winter. cant wait for spring.
Bubbajones_ya
Jul 6, 2024 08:32 PM
db057
Apr 28, 2019 07:45 AM
PurelyPMD
May 5, 2016 04:57 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
GTAman
Sep 26, 2015 02:01 PM
