What heads came on 89 350?
Old Nov 16, 2006 | 11:44 AM
GreenChevelleSS's Avatar
Car: 1970 Chevelle SS 396
Engine: 414ci Big Block Chevy
Transmission: Muncie Turbo Hydromatic 400
Whats the casting number for the heads on a 89 Iroc 350 TPI? They were never changed so anyone have an idea?
Old Nov 16, 2006 | 11:59 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
083.
Check mortec.com
Old Nov 16, 2006 | 01:43 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The full number is 14101083. For reference, the 87+ 305 TPI heads are 14101081.
Old Nov 17, 2006 | 12:10 PM
Thanks guys,
Anyone know where to get the flow numbers for them?
Old Nov 17, 2006 | 12:14 PM
They're stock heads.
There's LOTS of variation from one head to another, and one cyl to another. Even if you got "the flow numbers" that somebody else measured, there's no way to know that they're the same as yours. Or really, even very close.
Most of them flow in the very low 200s (like 200-205) on the intake and high 130s to low 140s on the exhaust.
Old Nov 17, 2006 | 02:05 PM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
Originally Posted by GreenChevelleSS
Thanks guys,
I knew I'd seen that somewhere...
Looks like sofakingdom was really close with his recollections. I'm not sure how the iron head compares, but the aluminum L98 head doesn't seem to be the greatest performer, even for stock heads... (You'll need to scroll down a bit)
Old Nov 17, 2006 | 10:09 PM
Thanks guys The Desktop Dyno's not real accurate anyway Id just like to have an estimate at what we are hitting. Ill use the flow numbers for the aluminum and reduce it alittle to get about what the cast Iron heads should be.
Old Nov 18, 2006 | 01:44 PM
kdrolt's Avatar
Car: 93 GM300 platforms
Engine: LO3, LO5
Transmission: MD8 x2
https://www.thirdgen.org/forums/tbi/...-headflow.html
Old Apr 5, 2023 | 05:14 PM
Kain's Avatar
Re: What heads came on 89 350?
Do you possibly know if headman headers off of 3998993 heads will work on my 1989 iroc 350 tpi heads? (sorry I am young and just getting into this sort of stuff)
Old Apr 5, 2023 | 05:23 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Sbc pattern will bolt up on exhaust side. But if the headers were in a different application no they won’t work
Old Apr 6, 2023 | 06:00 AM
Kain's Avatar
Thank you! They came out of a 3rd gen, with that being said they should work correct?
side note: I can’t believe someone actually responded since this forum is from like 15 years ago haha.
Old Apr 6, 2023 | 10:47 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
The 083 heads are very modest in stock form.
But get very good when fully ported with bigger 2.02x1.60 valves.
The lowest cylinder head parameter in DTD models a stock 083 head. Flow is just under 200 cfm stock.
can go 235-240 ish full port w/1.94" valve.
Can go 260 cfm w 2.05 and full effort port.
If you want to go fast spend your time porting the heads not playing on DTD.
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
theshackle
Mar 5, 2017 06:37 PM
NinjaNife
Aug 23, 2015 11:49 AM
NWAsonoma
Aug 18, 2015 05:45 PM
