Clearance
Old Dec 2, 2006 | 06:27 PM
lanmankilla's Avatar
Car: 84 Z28
Engine: LG4
Clearance
Yeah i was just wondering how much clearance is under my 84 Z28 hood, to add a new intake manifold and/or new air cleaner. My buddy told me theres no way i can add any of that without getting a new hood.
Old Dec 2, 2006 | 06:50 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Theres room.
Old Dec 2, 2006 | 07:03 PM
Damon's Avatar
Depends on the manifold. A standard Performer intake will fit no problem. A Performer RPM is tight, but it'll fit with proper air cleaner selection.
Old Dec 2, 2006 | 07:21 PM
Z28er's Avatar
Car: 84 Z28
Engine: 305HO
Transmission: Borg Warner T5
Axle/Gears: 3:73
I just installed a performer RPM intake under my stock Z28 hood,modded the bottom of the duel snorkel breather to fit on my holly carb and cut a peice of sheet metal for a cover.it is very tight but it works
Old Dec 3, 2006 | 07:04 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Originally Posted by Z28er
I modded the bottom of the duel snorkel breather to fit on my holly carb and cut a peice of sheet metal for a cover.
I had a Performer (with poly motor mounts if that makes a difference) on my old LG4, along with a dual snorkel. The fit was close enough that the imprint of the air box could be seen in the underhood insulation.
Off topic: Z28er, what Holley? How'd you modify? What you do for an air cleaner after modification?
JamesC
Old Dec 3, 2006 | 07:56 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I hate to even say it but your friend is an idiot. I hate people who can't think positive. [Though hating them is an oxymoron.] I just don't like when folks can't think outside the box. They assume everything is to hard to even try. Unless some fancy mag told them it works.
You know a "good friend" was standing there saying similar 1000s n 1000s of years ago when the wheel was being invented.
round rock dumb uga bouga
Though it should be obvious from now on, don't take or listen to advice from him.
Just about any will fit under your stock hood with a little positive thinking and work. There is always a way. But if your depending on your friends advice a CC and a summit catalog, think again.
Just take it slow and go one step at a time.
Here is just a quick one done as a cut away. Like ya see on show cars. Ya run everything low and on the sides. air filter slips down and around the carb.
Old Dec 3, 2006 | 08:13 AM
Z28er's Avatar
Car: 84 Z28
Engine: 305HO
Axle/Gears: 3:73
ok i'm a lil busy now but this evening i'll take some pics of what i did if you want?its not very hard,like someone said above,"theres a way".and i don't have the polyurithane mounts either.oh ya i'm running a 670 holly VS
Old Dec 3, 2006 | 08:19 AM
JamesC's Avatar
I'd appreciate your effort.
JamesC
Old Dec 3, 2006 | 01:04 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
Take a few tall pieces of clay and stick them to the top of your air cleaner. Then close the hood. The hood will smash down the clay, and you'll see exactly how much room you have to play with.
Old Dec 3, 2006 | 01:10 PM
Car: 84 Z28
Engine: LG4
ah thats a good idea with the clay. Thanks for the advice guys.
Hello eric!Hello eric!Hello eric!Hello eric!Hello eric!
Old Dec 3, 2006 | 06:17 PM
Z28er's Avatar
Car: 84 Z28
Engine: 305HO
Axle/Gears: 3:73
heres what i did to the breather.all you have to do is cut holes for the fuel lever adjustments to make it sit right down on the carb
Old Dec 3, 2006 | 06:28 PM
Z28er's Avatar
Car: 84 Z28
Engine: 305HO
Axle/Gears: 3:73
heres one with it all together,and i never got a chance to paint the cover.in the other pic you can see how snug it fits onto the carb now
Old Dec 5, 2006 | 05:57 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I kinda don't get the one pic.
Why have dual snorkles but have the lid spaced up like an open element filter???
Old Dec 5, 2006 | 08:00 PM
Z28er's Avatar
Car: 84 Z28
Engine: 305HO
Axle/Gears: 3:73
well i don't have it all finished yet.i just got it to clear,that was my main project.i still have to clean up the cuts on the bottom peice of the breather and for the cover,bend the edges down to fit snug to each other.the main thing is that i got it to fit under the hood.
z 28 jari
Sep 14, 2021 10:03 PM
91 SrS
Oct 7, 2015 04:32 PM
86z89iroc
Oct 5, 2015 01:04 PM
Night rider327
Sep 16, 2015 02:20 AM
