car runs fine for abt 30 min.....
Old Jan 1, 2007 | 05:49 PM
92rs365hp's Avatar
Car: 2011 dodge journey
Engine: v6 vvt
Transmission: auto
Axle/Gears: ???
its fine for like 30 min. then when you shut it off and let it sit for like 15 it wont start it will crank and try to turn over but wont hit but after 10 min or so it hits and starts right up the fuel pump is working and its got me baffled I put a new ecm in it and its not throwing any codes out I suspect the map sensor,,,,,,can anyone give me some insight to this problem????oh it a 5.0 tpi 91 z28
Old Jan 1, 2007 | 08:28 PM
fire350tpi's Avatar
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
Test the ignition module on the distributor they like to fail when they get hot
Old Jan 2, 2007 | 08:26 AM
92rs365hp's Avatar
Engine: v6 vvt
Transmission: auto
Axle/Gears: ???
it has a new one on it
Old Jan 2, 2007 | 04:11 PM
cameo's Avatar
Engine: 400 sbc, miniram, fast burn heads
Transmission: art carr 700r4
Axle/Gears: 3.54.s
do you have headers? are you sure you are not heat soaking your starter?
Old Jan 2, 2007 | 06:56 PM
92rs365hp's Avatar
Engine: v6 vvt
Transmission: auto
Axle/Gears: ???
no headers starter motor turns fine and starts fine just wont hit on spark..I am going to pull the ign.mod and go have it checked and I got plugs,wires,cap,rotor for ithope this fixes it,,,,,,,,,,,,,thanks for the tips
theshackle
Mar 5, 2017 06:37 PM
Wade787b
Sep 29, 2015 01:15 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Kaweh
Aug 9, 2015 02:54 PM
Sherpajames
Aug 7, 2015 06:56 PM
