won't start
Old Jan 14, 2007 | 05:03 PM
89Vert's Avatar
Car: '89 Iroc Vert
Engine: 355 TPI
Transmission: T-5(for now)
Axle/Gears: 3.45 9 Bolt
won't start
cranks fine, tons of fuel pressure,
no spark, and injectors aren't firing,
have tried different ECM and proms, my scanner hooks up and logs fine,
no codes, non vats car
88 TPI,
any where I should look thanks?
Old Jan 14, 2007 | 05:32 PM
89Vert's Avatar
Car: '89 Iroc Vert
Engine: 355 TPI
also ECM is getting all required grounds and powers,
and its intermitent,
sometimes its starts but runs rough until warm
Old Jan 14, 2007 | 05:54 PM
Gramps's Avatar
Car: 87 Camaro IROC
wait what?...it has no spark but u got it to start?...whats the real story here?
Old Jan 14, 2007 | 06:38 PM
89Vert's Avatar
Car: '89 Iroc Vert
Engine: 355 TPI
sorry when it doesn't start, it has no spark and the injectors don't fire
when it does it has spark and the injectors fire fine,
I got an inline spark tester on it and a noid light,
example today, its my bros car btw
my bro was cranking I was watching spark tester and noid light, niether would light up,
went inside and printed some schematics off the computer came out, checked again, he cranked, noid light and spark tester both lighted up, and it fired up, worked fine, but now its not firing again
Old Jan 15, 2007 | 03:01 PM
89Vert's Avatar
Car: '89 Iroc Vert
Engine: 355 TPI
I'm really stumped on this 1,
does anybody know what conditions have to be met for TPI to fire fuel and spark?
does the ecm need to see a distributor signal to fire the injectors?
I'm thinking its distributor related cause it should create sprak no matter what the ECM is doing, no?
and if the distributor isn't getting a reference the ecm wouldn't sense rpm, and not fire the injectors?
I'm just knid of grasping at straws here and I don't have the proper test equipment to check if the distributor is working correctly,
any help would be great
Old Jan 15, 2007 | 03:57 PM
Gramps's Avatar
Car: 87 Camaro IROC
if you turn your key to the ON position, your pump will come on for like 5 seconds then shut off (unless you start the engine) just to prime to injectors. when you turn your key to ON, does the pump come on for 5 secs? mayb its an ignition switch.
Old Jan 15, 2007 | 04:24 PM
89Vert's Avatar
Car: '89 Iroc Vert
Engine: 355 TPI
yes, fuel pressure is fine, with a noid light on, the injectors aren't firing,
I also have no spark,
fuel pump is fine, it was replaced with a performance 1 last year, fuel system is up to par, motor/car are built for nitrous, haven't put the bottle on it yet
seems like 1 problem after the next with this thing
Old Jan 24, 2007 | 12:00 AM
89Vert's Avatar
Car: '89 Iroc Vert
Engine: 355 TPI
fired an new dissy in and shes good to go
Old Jan 24, 2007 | 07:41 AM
Vader's Avatar
Pickup coil or module?
Old Jan 26, 2007 | 02:56 PM
jsmith929's Avatar
Car: 88 gta
Engine: 5.7
Transmission: 700r4 with 2400 stall
Axle/Gears: 9 bolt 3.23
When you had this problem did you haven a SES light or was it off,mine's kinda doing the same thing as you described .I just replaced the module and had spark but I still have no inj. pulse
Joe
Derick15
Sep 17, 2016 05:28 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
EFR2000
Aug 18, 2015 08:54 PM
