350 or 305
Old Jan 17, 2007 | 09:14 PM
z28boy88's Avatar
Car: 1983 Camaro Z28
Engine: 305 V8
350 or 305
this might sound kind of dumb, but is there anyway i could tell if my 1983 z28 has a 305 or a 350 in it, its suppose to have a 305 in it, like is there different starter sizes or anything. thanks
Old Jan 18, 2007 | 01:00 PM
ResurrectingZ's Avatar
Car: 1987 IROC 1991 RS
Engine: 5.7 TPI 5.0 TBI
Transmission: T-5 , 700R4
Axle/Gears: 2.73 twice
Check the portion of the VIN that is stamped on the block. Or just check the casting numbers on the back of the motor.
Old Jan 18, 2007 | 01:10 PM
Gramps's Avatar
Car: 87 Camaro IROC
the 8th digit of your VIN code will tell you if its a 305TPI(will have letter F) or a 350TPI(will have number 8), but since i see you have a carb then your letter will be an H and you have a 305, no camaros came w/ a 4bbl carb and a 350 stock. and there is a difference between starter sizes because of different flex plates. and even still you may have to shim it to make it engage perfectly.
Old Jan 18, 2007 | 01:19 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
An 83 could only have has a 305 from the factory. The 350 wasn't available until 1986 and only came with TPI.
That doesn't mean it couldn't have been replaced by a 350 at some point though. Check the casting numbers to be sure.
Checking the casting numbers or disassembling and measuring the bore are the only way to distinguish a 305 from a 350. There are absolutely no other ways to tell with certainty.
Old Jan 18, 2007 | 05:03 PM
z28boy88's Avatar
Engine: 305 V8
ok ill look at the numbers ima switch distributors anyways,im putting an mallary ignition distributor and high energy coil
Old Jan 18, 2007 | 05:31 PM
Gramps's Avatar
Car: 87 Camaro IROC
sounds awesome, let us know what you got under the hood.
Old Jan 18, 2007 | 06:29 PM
84L69TA's Avatar
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
Um, that would be 1987
Old Jan 18, 2007 | 07:01 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Yeah, 87... silly fingers.
Old Jan 22, 2007 | 06:40 PM
z28boy88's Avatar
Engine: 305 V8
ok the i was told that the 350's didnt come stock with a carberator so the engine has to be a 305, but if its original is unkown, the 8th letter on my VIN is the letter h which does mean carberator but ive got the number on the pad behind the altenator the number is 11191C
Old Jan 22, 2007 | 07:21 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The casting numbers on the block behind the drivers side head are more useful.
Old Jan 23, 2007 | 06:42 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
'86 is correct, if you're talking calendar year.
'87 if talking model year.
Except a few 350s were delivered in California in the '86 model year. https://www.thirdgen.org/1986-chevy-camaro
Old Jan 23, 2007 | 09:00 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Whether or not any of those 86 350s still exist will probably continue to be debated for years to come.
I'm inclined to believe they're all parked in a secret warehouse, right next to the steel-bodied 83 Corvettes with the carburetors that got 200 mpg burning water.
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Dwayne614
Sep 28, 2015 08:33 AM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
