GM Ingenuity: Changing the Spark Plugs on the LG4
Old Jan 21, 2007 | 01:35 AM
Fireluxx's Avatar
Car: 1982 Camaro Berlinetta
Engine: LG4 5.0 V8
Transmission: TH200C 3-Speed
It is necessary to have the front end lifted up so that one can change the spark plugs? Here I am all ready to swap out the old plugs with NGK's and the exhaust manifolds are blocking the plug wires. Did GM seriously design the LG4 so that you have to replace them while being under the car?
Thanks for reading my rant/question.
Old Jan 21, 2007 | 02:10 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
If you mean access to the plugs from underneath the car, yes, I can only access the 5 and 7 plugs from underneath, but I have SLP headers.
6 and 8 will be a problem when I reinstall the A/C housing.
Old Jan 21, 2007 | 02:17 AM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
when i had the LG4 in my car back in the day, i was able to change all of the plugs from above. wasn't fun, but i managed with a lot of swearing...stupid manifolds.
Old Jan 21, 2007 | 02:34 AM
Bitza's Avatar
Car: 1982 Z28
Engine: 305 Carb
Transmission: 4 Spd Saginaw
Axle/Gears: 3.23LSD
Mine being RHD make changing plugs a challenge, more so with the steering shaft being close to the manifold.
Old Jan 21, 2007 | 10:54 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
No, like mentioned you can get them from the top. The only thing is you must accept the fact that you hands are going to get cut up a bit.
Old Jan 21, 2007 | 11:08 AM
Fireluxx's Avatar
Engine: LG4 5.0 V8
This is going to be a fun day...
Thanks for the replies.
Old Jan 21, 2007 | 12:08 PM
Magman's Avatar
Car: 1990 IROC-Z
Engine: 383 HSR
Axle/Gears: 3.70
You will have much better accesss changing most of the plugs from below. Just jack the car up and crawl under there. It will easily cut the time spent doing this job in half.
Old Jan 21, 2007 | 12:43 PM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Very hard to do from above, if you don't have any just buy some cheap ramps and drive the car up on them, takes all the work out of it.
Old Jan 21, 2007 | 05:22 PM
Fireluxx's Avatar
Engine: LG4 5.0 V8
One of my friends has a proper jack that I can use to lift up the front end. Seeing that he was a mechanic, I'll leave the work to him while I'll observe and learn at the same time.
Old Jan 21, 2007 | 06:16 PM
Gramps's Avatar
Car: 87 Camaro IROC
peh, if you want a challenge, try a toronado (V8 Front wheel drive), you gotta remove wheel wells to get at the suckers. makes me appreciate the newer designs a little better, regardless of how many knuckles i busted.
eightsixseven
Dec 16, 2024 01:50 PM
apo_bailon15
Mar 28, 2016 05:20 AM
evilstuie
Feb 28, 2016 03:33 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
