question about map sensor
Old Jan 23, 2007 | 05:07 PM
92rs365hp's Avatar
Car: 2011 dodge journey
Engine: v6 vvt
Transmission: auto
Axle/Gears: ???
how can I tell if my map sensor is bad or going bad with out getting it tested???
Old Jan 23, 2007 | 11:18 PM
AtomicTruck's Avatar
Car: Pro Stadium Tough Truck
Engine: Buick V6 272 cu in
Transmission: TH350
Axle/Gears: Broken most of the time
Well, Ive never tried this (yet) but I was thinking about doing it till I found out I had the vaccum lines hooked up wrong.
Put a multimeter (resistance) on the MAP, hook up a section of new hose (tastes better) and suck on it. You should see the resistance change.
Again, I almost tried this but didn't. Try it at your own risk but please post results if you do.
Old Jan 24, 2007 | 03:36 PM
92rs365hp's Avatar
Engine: v6 vvt
Transmission: auto
Axle/Gears: ???
thats a kinda odd way to test it dunno if I wanna try it or not maybe I can get my wife to do it
Old Jan 26, 2007 | 09:14 PM
Transmission: TH350
I'm glad you saw the humor in that post. I was LOL while typing it. The real funny part is that I was actually going to do it. Thankfully, I found that I had plumbed the vac lines wrong.
Charles
Old Jan 26, 2007 | 09:17 PM
bobdole369's Avatar
Car: 1989 Firebird
Engine: 2.8L V6 MPFI
Transmission: Beat to heck 700R4
Technically that ought to do it. You've gotta have power to it though. I'm not familiar with MAP, so I don't know if the engine needs to be running or not.
A more accurate test would be to measure its voltage whilst sucking on it, instead of its resistance. They do sell handheld vacuum pumps for just this purpose.
Old Jan 26, 2007 | 09:37 PM
Transmission: TH350
OK. Now I'm going to have to figure this out. I have a vac pump for vac forming small plastic parts for my RC airplanes... I'll try to find some time to replumb and test this stuff out. Don't hold your breath (pun intended).
Charles
Old Jan 27, 2007 | 01:03 AM
bobdole369's Avatar
Car: 1989 Firebird
https://www.thirdgen.org/forums/tech...ge+temperature
Vader already did this, or at least relayed the info....
Old Jan 27, 2007 | 03:38 PM
92rs365hp's Avatar
Engine: v6 vvt
Transmission: auto
Axle/Gears: ???
ok here goes it I tried the whole sucking on hose thing with multimeterbut instead of hose I used a straw from mcdonalds (pause for the laugh).............and hooked up meter then sucked on straw noting on meter from old map so went and got new onetried the same and worked ok so the whole straw and multimeter thing does actuall work
a big thanks to atomic truck,,,,,,,,,,,,,,steve
Old Jan 28, 2007 | 01:54 PM
Transmission: TH350
Thanks for the link bobdole. I'll do some testing and add some resistance values to go with the voltage.
9192camaro
16
Feb 3, 2019 12:21 AM
Caspar
Jun 19, 2016 11:19 PM
soarestransam
Aug 24, 2015 08:15 AM
91REDZ28VERT
Aug 18, 2015 10:16 PM
squiggy2
Aug 9, 2015 09:30 PM
