AFR 210's
Old Feb 2, 2007 | 07:16 PM
85Firebird350's Avatar
Car: 1984 Firebird T/A
Engine: 406sbc
Transmission: TH400
Axle/Gears: Moser 9"
AFR 210's
Are the AFR 210cc race ready heads too big for the cam I want Lunati Voodoo 241*/249* @.050 with .525/.546 lift? I see them on their website but on a 406ci engine. The setup is almost exactly like mine except 406ci as to my 383ci, making 550hp at the flywheel sounds really nice to me though.
Old Feb 3, 2007 | 01:23 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Which are you thinking of changing, the heads or the cam?
I think those heads are maybe a tiny bit too big for the cam. But, would you rather go up a step in cam, or down a step in heads? hmmm, indeed.
Old Feb 3, 2007 | 01:33 AM
Engine: 406sbc
Transmission: TH400
I dont want to go a step up because my car is primarily a street car and the rpm range on that cam is already 2500-6500 but a step down in head would go from 210 to 195 which I don't really want to do.
Old Feb 3, 2007 | 02:51 AM
Sonix's Avatar
Car: 1982 Trans-Am
ah, I see.
Then I think it'd work out alright.
Old Feb 3, 2007 | 02:55 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Noke that ****...."JUST DO IT", should be just fine, be sure you have a good intake to support it, as well as a properly tuned carb, good luck.
Old Feb 3, 2007 | 06:17 AM
Engine: 406sbc
Transmission: TH400
I'm not sure if you think the edelbrock performer rpm is a good enough intake but thats whats on there now. Should be fine right?
Old Feb 3, 2007 | 08:52 AM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
I think the 210cc heads will be fine with that cam, I wouldn't hesitate to use them. If you go with the 210's you won't have to worry about being mismatched later if you step up to a larger cam. Those heads would love a solid roller in the 250-260dur@.05, .600+ lift range.
The performer RPM should be fine with your combo too, but I would have it port matched if it isn't already. I ran very similar cam(242/248@.05, .540/.560lift) with a RPM airgap and it worked great. You probably wouldn't see any gains with a single plane unless you went to a larger cam with a higher power band.
Old Feb 3, 2007 | 08:56 AM
Engine: 406sbc
Transmission: TH400
Would I be able to find a solid roller cam like that to run in the 2500-6500rpm range?
Old Feb 3, 2007 | 11:28 AM
Sonix's Avatar
Car: 1982 Trans-Am
Yes. The smallest solid roller or so. Not a lot of benefit to a solid roller below 6000RPM though. Also, if it'll be street driven, you'll want a way to get oil to the roller. Grooved lifter, or putting a groove in the bore is popular.
Old Feb 3, 2007 | 05:46 PM
cc 82Z-28's Avatar
Car: 82 Z-28
Engine: Built 406ci
Transmission: 700R4 w/3000 stall
Axle/Gears: 3.73 Torsen Posi, Moser Axles
Is that the hyd. flat tappet or a hyd. roller? I think your combo should be killer and I say go for it. I am going to use the Voodoo hyd. roller #60112 which has .535/.550 and .231/.239 @ .050 lift in my 400 I am building. Good luck with your build..
TX-SleeperC5
Feb 24, 2016 01:34 PM
ULTM8Z
Oct 2, 2015 01:25 PM
355tpipickup
Sep 28, 2015 05:50 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
randywyatt200
Sep 9, 2015 04:27 PM
