Vacum Pump Options?
Car: 92 Z28 Camaro
Engine: Procharged 406.
Axle/Gears: Moser 9" 4.11 Gears
Vacum Pump Options?
looking to buy a vacum pump. Are there any other options other than Moroso, Star Machine, GZ Motorsports? Which one do you perfer for the street?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
For the street? You don't need one. You're not going to see any power gains operating at such low rpm levels.
On my race engine I use a modified LT1 electric smog pump as a crankcase evac system along with a traditional header evac system. When my engine is shut off and cooling down in the pits I can leave the electric pump on to suck the moisture out of the crankcase which keeps my alcohol contaminated oil, cleaner.
If you feel you just need to have one, GZ is one of the most popular belt driven. Star makes a nice 24 volt version which is used in Pro Stock cars.
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
i beg to differ.. LOL.. granted this is probably for a different reason but i need one for my brakes.. i used to have a 294S cam and that barely workd the brakes.. now i have the 306S and braking without the pump isnt an option.. i might as well step on a rock.. but the vaccum pump works like a charm.. i have a stainless steel brake company one for my brakes..
i'm gonna need one for my motor soon too.. positive crankcase pressure blows.. literally.. haha.. i have to wipe off oil from the wiring to my starter every week.. its getting to be a pain..
Car: 92 Z28 Camaro
Car: '88 IROC-Z medium orange metallic
The moroso piece works good on the street, so does the Aerospace kit. I try to stay away from Star. They have some poor business practices.
There's nothing wrong with running a vacuum pump on the street. I don't think low RPM power is his main reason for using one. If you're getting blowby and pressure in the crankcase that no PCV system can cure then you need a pump.
How is your PCV system hooked up? With a blower you're going to want a second valve that gets vacuum from the intake side of the blower. If you have a single factory setup that runs from the intake to a valve cover it will work against itself because under boost there is no vacuum in the intake. Making yourself an additional line may save you the need to get a vacuum pump.
Car: 87 IROC L98
All the typical belt driven, 3 vane, complete crankcase vacuum pump systems are in the $700 - $1000 range.
Car: 1983 Camaro Z28
Engine: 584
Transmission: TSI Glide
Axle/Gears: Quick performance 9 inch
In a race application what kind of power gains does the vacuum pump provide? Just figured I would ask since everyone is on the subject. I have heard it's only like 5-10 horses.
Car: 92 Z28 Camaro
You should have one. If you're having crankcase pressure problems that could solve them. Talk to your engine builder. If he set up the ring gaps and designed the engine around the asusmption you would be using a vacuum pump then you need one.
Car: 92 Z28 Camaro
The driver side is taken up by the S/C compressor and P/S pump. The passanger side is taken up by the alternator with a head mounted position. Only space I can think of is Pass side down low near the crank? That would mean I would need a block plate?
I would try a proper PCV setup first and see how it does. I'm guessing the builder has an engine dyno? What kind of evacuation system did they use while breaking in and testing it? You'll probably have to make yourself a bracket to mount the pump if you decide that's the way you want to go. There isn't going to be an off-the-shelf kit to install it. I would use a low mount alternator kit and put the vacuum pump above it near the pass. side head. I've got a small block on the dyno now with a Moroso pump mounted up high like that, I'll try to get a picture of it and post it for you tomorrow.
Car: 92 Z28 Camaro
I don't see a PCV system, just a pair of breathers that wont do ****. You'll want to run a hose from the intake to a valve cover to supply the crankcase with vacuum. On an N/A motor that would be sufficient but when under boost it obviously wouldn't work since there will be no vacuum in the manifold. To provide vacuum when under boost you'll want to run a second hose from the intake side of the blower to another PCV valve located in the valve cover.
