Engine Life points
Old Feb 14, 2007 | 06:08 PM
Cambridge205's Avatar
Car: 89 GTA
Engine: L98 350
Transmission: Swapped to a T-5
Engine Life points
I'm removing my TPI engine very soon and I want to take it out with all the accessories attached but with the tranny left in the car (its a manual). I have read about hooks that GM used to install the engine but I don’t see them in the driver’s front or passenger’s rear. So I was thinking on lifting it from the intake bolt holes, one in the front driver’s and one in the passenger’s rear and I plan on using grade 8 bolts for the removal. Is this a way to take an engine out? Or is it too dangerous? Another thing is, if I did it that way would the bolted chain links bend or break because of the 90-degree angle that the bolted link is at? Any help is appreciated thanks.
Engine lift points not engine life points. Sorry!!!
Last edited by Cambridge205; Feb 14, 2007 at 06:11 PM. Reason: Automerged Doublepost
Old Feb 14, 2007 | 06:26 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
Just use the front two and rear two intake manifold holes. Balances the weight. I perfer to take the transmission out with the engine though. Plenty easy.
Vintageracer
Jan 10, 2020 05:33 PM
Infested
May 22, 2018 11:56 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
