92 Formula need some help
Old Feb 14, 2007 | 09:54 PM
bobp53916's Avatar
Car: 92 Formula
Engine: 305 TBI
Got a serious problem with my 92 Formula, last weekend the fuel pump went out so I changed that, then I went to start it, it would spin over but wouldnt fire, when I let off the key it would fire. I brought it in the garage tonight to figure it out now it wont fire at all. It has no spark, and after spinning it over a few times now the starter wont engage at all, I tried a different switch for the ignition on the column and checked the ecm fuse but everything seems to be fine. Any other reasons it would do this? The ECM? I'm at a loss with this one. Any suggestions would be greatly appreciated.
Old Feb 14, 2007 | 09:57 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
is your battery dead?
Old Feb 14, 2007 | 10:01 PM
bobp53916's Avatar
Car: 92 Formula
Engine: 305 TBI
No the battery is fine, it was spinning over and then I tried it again and wouldnt spin over. Sorry, its a 305 TBI.
Old Feb 14, 2007 | 10:05 PM
Car: 91 RS
Engine: 350 vortec
when was the last time you tried to turn it an hour? 20 min? try it again with full throttle...
do the injectors pulse when you are turning the car over ? are you hearing the fuel pump prime?
Old Feb 14, 2007 | 10:15 PM
bobp53916's Avatar
Car: 92 Formula
Engine: 305 TBI
About an hour ago, the fuel pump does prime when I turn the ignition but the starter doesnt engage, no clicking no nothing. It acts like if you pulled the ecm fuse.
Old Feb 14, 2007 | 10:18 PM
Car: 91 RS
Engine: 350 vortec
1 try starting it again now with WOT
2 make sure it isnt in gear as in play with the shift lever a bit
Old Feb 14, 2007 | 10:30 PM
bobp53916's Avatar
Car: 92 Formula
Engine: 305 TBI
Nope, nothing at all. Fuel pump runs but no starter...Do you think it could be the ECM?
Old Feb 14, 2007 | 10:36 PM
Car: 91 RS
Engine: 350 vortec
Nope
Linson
Oct 24, 2025 02:00 PM
okfoz
Oct 13, 2015 02:19 PM
bjpotter
Oct 4, 2015 07:48 PM
Linson
Oct 1, 2015 09:50 PM
