Oil Pressure Sending Unit
Old Feb 22, 2007 | 06:21 PM
clewis's Avatar
Car: 1985 IROC-Z
Engine: 305 Tuned Port Injection
I've already determined through help from this board that my OPSU is kaput. Do they leak when they've gone bad? Is there anything in particular I need to know about how to change it? I've never changed one out before.
Old Feb 22, 2007 | 06:35 PM
SPIKE's Avatar
Car: 86 CAMARO
Engine: 92-350 +.030
Transmission: 86-th400
it will leak if its broken. but they can go bad and not leak also. just disconnect wire, unscrew, put thread sealer on new one, screw in, hook wire back up and your good to go.
Old Feb 22, 2007 | 06:41 PM
clewis's Avatar
Car: 1985 IROC-Z
You make it sound pretty easy. It looks like it's in a pretty tight spot.
Old Feb 23, 2007 | 07:31 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
It is easy.
Everything's in a tight spot on these cars. That song changed when I had to start working on my 00 TA. Talk about packing it in.
Old Feb 23, 2007 | 08:42 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I changed mine twice yesterday and will probably change it again this weekend with a brand new one.
Had one sitting in the garage so I decided to try that and it was dead, so I borrowed one from my friends Iroc and it reads funny, 45psi at idle and 60+ (60 is the max on my gauge) on WOT. I am pretty sure my 170K mile motor isn't producing that much pressure.
I have headers (no AIR tubes) and the HSR so there is plenty of space to see the sender and I just used a deep 19mm socket and short extension and had the ratchet near the bottom of the wiper motor.
Took a few seconds to remove and a few more seconds to put back on.
Old Feb 23, 2007 | 08:55 AM
90CamaroTBI's Avatar
Car: 91 Formula, 89 IROC
Engine: LB9, LB9
Transmission: 700R4, 700R4
Axle/Gears: Posi 2.73, Posi 2.73
Just changed mine yesterday and the only tool that I could get to fit the stock unit is a 30mm wrench! The new one was only a 1 1/16 wrench. Mine just reads a constant 30 at all times so I dunno. I didnt tighten mine really tight but I did use teflon tape. I was afraid to tighten too much.
Old Feb 23, 2007 | 11:38 AM
MD83Z's Avatar
They have two senders if I recall corectly...a 40psi and a 60psi ...you need to check the gague in the dash and match its limit. I bought the wrong one and the guage is usually pegged.
Old Feb 23, 2007 | 12:31 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
FYI
If one wire, the ground circuit is completed through the sensor body, if the thread sealer isn't conductive the gauge won't work properly.
Old Feb 23, 2007 | 09:39 PM
clewis's Avatar
Car: 1985 IROC-Z
Well, I got the old one off, but now I'm having a heck of a time getting the new one to go in. My local parts store sold me a Borg Warner OPSU part number S996. It won't screw in. It just turns. In comparing the two, the old and the new, there is a slight difference in the overall size of the part, and it looks like the part that screws in on the old one is slightly more beveled. The old part screws right back in with no problem.
Does anyone have the correct part number?
1985 IROC-Z, 305, TPI.
Old Feb 24, 2007 | 02:04 AM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
DelCo D1829
Borg-Wagner sells Neihoff part# OP24721
Old Feb 24, 2007 | 03:27 AM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
Do not use Teflon tape, use an electrical conductive sealer i.e. graphite grease.
Old Feb 24, 2007 | 06:27 AM
clewis's Avatar
Car: 1985 IROC-Z
Hey thanks for the reply. I just put the old unit back in so I can drive the car today. I'll stop by after work and see if they have the one you mentioned.
Ghettobird52
Jul 5, 2024 11:18 PM
89GTAOz
May 16, 2020 09:31 AM
Infested
May 22, 2018 11:56 PM
355sbcTPI
Aug 19, 2015 04:38 PM
