Oil leaking out of grommets and dipstick
Old Mar 2, 2007 | 04:38 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
The car is my dad's 92 Z-28. Oil has been leaking out of his grommets on the driver and passenger sides, and dipstick the past couple of weeks. What causes that to happen? The PCV valve and hose was replaced a couple months ago. Also replaced the hose on the passenger side at the time.
Old Mar 2, 2007 | 05:57 PM
Chris's 85z's Avatar
Car: 85 Z
Engine: 383
Sounds like the PCV valve or you have some bad blow bye from the rings.
I would double check the hose routing to make sure everything was put back in the right spot.
Did it do this before you replaced the PCV valve? If so I would lean more towered the rings are not sealing like they should.
How many miles are on it? If you take the PCV valve out, when you shake it does it rattle?
Old Mar 2, 2007 | 07:30 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
better do a compression check on all cylinders
doesnt sound good..
sounds like alot of crankcase pressures
run away fast
good luck
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
bamaboy0323
Sep 12, 2015 07:14 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
tgp1990
Sep 4, 2015 06:24 AM
