Just dropping in (lots of pics)
Old Mar 10, 2007 | 04:16 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
Hey guys, it's been quite a while since I've posted. Just letting you know I'm not dead. Unfortunately, I wrecked my winter car so I've been forced to drive my Firebird all season, and Michigan has taken its toll on everything. I figured I'd post some pictures of what I'm currently running.
I started with a bare 350 block, bored .040" over. It's a four-bolt main purchased from a fellow TGO member. The second motor I bought from him, actually.
I ported the Vortec heads I had, starting by laying the gasket on them. There was plenty of material to be removed- approximately .150" on the diameter!
They cleaned up pretty well. I did a 3-angle valve job on them after I was done cutting them up.
After honing the block, I was sure to clean out all of the coolant passages and oil galleys with compressed air.
Beginning assembly of the lower-end...
If you've ever removed an intake manifold, you'll have noticed the massive amounts of sludge that form on that spider retainer. Well I went ahead and added a preventative measure to this- mini drain holes!
Meaty H-beam rods
Here's a good picture of the bottom end assembled. What you can't see are the forged flat-top pistons! Properly adjusted the new high pressure oil pump and tack-welded the pickup, so it won't fall off.
Putting the valvetrain together is cake when you have a special tool to bleed out all of your lifters!
The crowning touches
Breaking it in on an engine stand was a GREAT idea... My damn FelPro intake gaskets didn't seal properly against my Vortec heads. I had to find my water leak and go through it all over again. What a waste of some break-in oil! Better safe than sorry- it's much easier to remove an intake when it's on a stand!
FINISHED PRODUCT:
Old Mar 10, 2007 | 06:27 PM
cool84's Avatar
Car: 84 trans am
Transmission: built 700r4
very nice. i wish i could break in a motor on a stand. i had to do my motor swap with a borrowed hoist and hope it worked when it went in.
Old Mar 11, 2007 | 09:32 AM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Originally Posted by Token
...Breaking it in on an engine stand was a GREAT idea... My damn FelPro intake gaskets didn't seal properly against my Vortec heads. I had to find my water leak and go through it all over again. What a waste of some break-in oil! Better safe than sorry- it's much easier to remove an intake when it's on a stand!...
Running mine in on a stand revealed a brand-new rear main seal that leaked. I woulda been screwed. It also helped remove the "temporary paint" from the headers. It's definately worth the hassle.
Old Mar 11, 2007 | 12:00 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
uh oh. What gasket do you mean there?
Old Mar 12, 2007 | 12:36 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The real way to avoid that is to use a real lubricant - not that stuff boiled off from crud pumped out of the ground.
Old Mar 12, 2007 | 04:01 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
I use synthetic only sir
header gasket of course!
Old Mar 12, 2007 | 04:37 PM
five7kid's Avatar
If it's a "real" synthetic, you shouldn't have to worry about sludge build-up in there.
Old Mar 12, 2007 | 05:05 PM
VenomX-87's Avatar
Car: 1984 Trans-Am WS6
Engine: WAS: 5.0HO, SOON: ZZ383-425HP.
Transmission: 700R4 with shift kit
Dude that engine looks sweet, i wish i had the time to build and engine for my T.A. i get like 3 to 4 hours a week spare.
when it comes to synthetic oil it is only like 5w20 isn't that to thin for our engines?
Old Mar 12, 2007 | 05:38 PM
five7kid's Avatar
Not sure what's on the shelves down under, but you can get synthetic in a bunch of different viscosity ratings. Check out http://www.amsoil.com/products/motoroils/index.aspx for one example.
Old Mar 12, 2007 | 05:44 PM
kaptinkafeen's Avatar
Great looking mill.
What type of valve covers are you using - I am having a hard time finding taller center bolt v.c. to accomodate higher lift #.
-Andrew
Old Mar 12, 2007 | 06:51 PM
Sonix's Avatar
Car: 1982 Trans-Am
haha, I was going to say, gee five7, got any lubrication suggestions?
Oh, exhaust, fair enough. I guess Vortecs are shabby on that side...
Old Mar 12, 2007 | 10:37 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
I run Mobil 1 5w40
Thanks man, I try
Originally Posted by kaptinkafeen
Great looking mill.
-Andrew
I think they're proform, but I'm not sure. I bought them polished but I took some scotch brite to them to cut the shine off
the Vortec exhaust is horrible!!!!
Old Mar 13, 2007 | 11:39 AM
five7kid's Avatar
You shouldn't have to run 5W-40, as 5W-30 would be fine unless you left clearances loose. But, Mobil 1 is better than the pretenders put out by the other major oil companies.
Did you gasket match the headers?
Old Mar 13, 2007 | 04:19 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Yeah I trmmed the headers up too
I picked 5w40 because I gapped my rings a little further, as this is a potential nitrous motor. I didn't want it to burn any oil so I went thicker. Is it still cool to go with 5w30?
Old Mar 13, 2007 | 05:22 PM
five7kid's Avatar
If you just gapped the compression rings wider for nitrous, no problem. If you gapped the oil control rings wider, that would be a problem (and the higher viscosity wouldn't help much).
How about your bearing clearance?
Old Mar 13, 2007 | 10:19 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
You know what I dont like about your motor?????????? ITS NOT IN MY CAR..............Looks really good man......Hope to see some vid of it running...Congrats...Tom
Old Mar 14, 2007 | 06:41 AM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Thanks Tom! I've already put about 5-6000 miles on it since I put the motor in the car last summer. I love it!
I didn't touch the oil control rings at all. And my bearing clearances are not abnormal, they're within spec... If I can recall about 1.5 to 2.5? they were all consistent for every rod, and every main. I just don't remember what it was. Everything was all milled before I assembled it.
Just wondering, why not use 40 weight?
Old Mar 14, 2007 | 06:55 AM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Mellow idling
Microphone inside the car
and please excuse my lame rolling stones joke, I can't get no.... f'ing traction... The car is squeaky as hell because that was the beginning of the cold season when everything starts to get noisy. You can distinctly hear a severe lack of traction from my 2.73 open rear with bald tires! But the exhaust note is cute.
Old May 22, 2009 | 10:55 AM
formula forever's Avatar
Car: 91 formula
Engine: 350 tuned port. bolt ons
Re: Just dropping in (lots of pics)
very nice
mustangman65_79
Apr 14, 2017 05:37 PM
87iroctheo
Dec 4, 2016 11:47 AM
TheExaminer
Aug 26, 2015 04:59 PM
TMoNeE
Northern California
Aug 24, 2015 06:11 PM
crazynights
Aug 21, 2015 06:53 AM
