cam swap no fire need help
Old Mar 17, 2007 | 11:10 PM
gapimpin's Avatar
Car: 1991 Pontiac Firebird
Engine: 383 LT1
Transmission: built 700r4 and fuddle 3500stall
Axle/Gears: 4th gen 3.42 auburn
we swapped a comp xtreem cam in a few weeks ago and just got the engine back in and everything bolted up today. we tried to start it but no luck. it makes a big chugging noise from the exhaust and after a while it shot flames out. i was playing with the timing but it did not work. too far advanced you get a fireball out the exhaust too far retarded and you get one out of the carb... could it just be valve lash? i didnt set it because it had already gotten dark out i just backed the nuts out so it was loose that way the valves wouldnt hang open. i really dont think that would keep it from starting though.
Old Mar 17, 2007 | 11:15 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Try lashing the valves to start.
Old Mar 18, 2007 | 09:52 AM
gapimpin's Avatar
Engine: 383 LT1
I was gonna do that today just wanted to see if thier was anything else i could doo. i had the valve lash so tight on my other motor that the valves wher haning open and it still started just didnt run well.
Old Mar 18, 2007 | 10:27 AM
intex1982's Avatar
Car: 89 formula/00 z28
Engine: carbed 350/ls1
Transmission: 700r4/ a4
Axle/Gears: 3.23 posi/ 3.73 posi
u need to get a book or something to read how to set ur valve rgt. i do it by going to tdc on each cylinder and set no lash and a half around more
Old Mar 18, 2007 | 12:55 PM
85irocinjected's Avatar
Car: 1991 RS
Also double check that you don't have your distributor 180
Old Mar 18, 2007 | 01:10 PM
Guest
Guest
Posts: n/a
Yea, thats what it sounds like to me. I'd just turn it 180 and try again. Bet it fires.
Old Mar 18, 2007 | 10:21 PM
gapimpin's Avatar
Engine: 383 LT1
thats what i found out it was. i was trying to do valve lash and one of the valves that i was trying to tighten was open so figured it was 180. i flipped a few wires around and boom she cranks and sounds like a beast... thanx for the help so far i have swapped an engine from a 305tbi to a 355 carb then took it out and did heads cam and exhaust all with info i found on this site.
Old Mar 18, 2007 | 11:35 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
nice to see the problem is fixed.. once, i put in my distributor one tooth advanced.. would barely turn over.. it would turn, then stop and spin the other way.. i thought i bent some valves or something.. turns out the timing was at 75* advanced and it was firing on the compression stroke..
Old Mar 19, 2007 | 01:02 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Somethings wrong if it DOESNT fire on the compression stroke
I know what you meant though... Too much advance will cause it to kick back
Old Mar 19, 2007 | 10:19 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Common problem when doing a cam swap. Instructions say to line the dots up on the timing gears when installing the chain. Instructions don't say that this puts #1 cylinder at TDC on the exhaust stroke. When #1 is at TDC on the compression stroke, the dot on the cam gear needs to be at the top.
Old Mar 20, 2007 | 01:14 PM
gapimpin's Avatar
Engine: 383 LT1
Re: cam swap no fire need help
so its not my dizzy that was 180deg out it was my cam? i put the cam in the same way it came out the dot was on the bottom. is that gonna cause any problems?
Old Mar 20, 2007 | 01:22 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
No, it was the distributor.
When the cam and crank gear are dot to dot, both #1 and #6 are TDC, but the cam is in #6 firing position. The distributor has to be installed with the rotor pointing to the #6 terminal.
Old Mar 20, 2007 | 01:36 PM
gapimpin's Avatar
Engine: 383 LT1
that scared me for a sec...
thanx for the info guys
anesthes
Mar 10, 2016 10:35 PM
Cameeeero
Sep 18, 2015 04:00 PM
gta90
Sep 15, 2015 04:00 PM
theurge
Aug 21, 2015 12:46 PM
86White_T/A305
Aug 17, 2015 12:16 AM
