Spark plug selection help...
Old Mar 25, 2007 | 07:10 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
This is for my buddies ride.. He was running bosh plat. plugs numbers off em are as follows WR9FP R3 289.. Having a lot of pinging with em when the engine gets hot, can anyone recommend a different heat range/plug? Thanks!
Old Mar 25, 2007 | 07:11 PM
82knightrider's Avatar
Transmission: TH200C....700R4
Re: Spark plug selection help...
Get ac delco brand
Old Mar 26, 2007 | 03:32 AM
BlkBird408's Avatar
Car: 89 Firebird
Engine: 408
Axle/Gears: 12 bolt/4.11
I also use AC Delco! Never had any problems with them.
Old Mar 26, 2007 | 05:42 AM
Pat Hall's Avatar
I've never figured out exactly why, but Bosch Platinum plugs perform completely awful in V8 motors. They seem to foul out very quickly. They work great in 4 cylinder engines though. I've always had good luck with AC Delco plugs in my V8, and even better results with Champions. All the fancier "gimmick" spark plugs really are nothing but gimmickry. Never tried the AC Delco "rapid fire" plugs, so I can't really comment on them from personal experience.
Old Mar 26, 2007 | 11:22 AM
Psycho_91Camaro's Avatar
Car: 1991 Camaro RS
Engine: THE LT1 SWAP SHALL BEGIN!!!!
Transmission: 700 R4
Axle/Gears: LSD! =(
AC DELCO RAPID FIRE!!!!!!!! nothing less!!!!
Old Mar 26, 2007 | 11:54 AM
89RsPower!'s Avatar
can anyone recommend a heat range?
Old Mar 26, 2007 | 12:45 PM
Guest
Guest
Posts: n/a
You never mentioned what your buddies ride was.
Old Mar 26, 2007 | 03:59 PM
89RsPower!'s Avatar
350 186 iron heads, 10.5 to 1 comp ratio forged internals, 650dp, rpm intake, some sort of comp grind... thats all I really know about the engine..
Old Mar 27, 2007 | 12:58 AM
Pat Hall's Avatar
Doesn't sound like an extremely radical motor. In those cases, what I usually do is just start out with the recommended plug for that particular year and motor. If it doesn't run optimal with the stock range plug, maybe go one step colder, but try the stock heat range first.
Old Mar 27, 2007 | 04:15 PM
89RsPower!'s Avatar
yeah its nothing too radical, it only made like 350 hp at the crank and 380 flbs or so, just a mild street build. I believe the above mentioned plugs were the stock range, I'll tell him to try something a range lower and go from there. Thanks!
Old Mar 27, 2007 | 08:29 PM
jonmark1985's Avatar
Car: 89' Pontiac Firebird
Engine: L03 carb Ported #87s new shortblock
Axle/Gears: 2.73 open
r45ts or i think like an r44ts is a colder plug
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
Jlanz55
Sep 9, 2015 09:09 AM
90formulaVortec
Sep 8, 2015 12:42 AM
89 formula TPI
Sep 7, 2015 11:06 AM
