top speed of 305
Old Mar 29, 2007 | 10:21 PM
woodstock16's Avatar
Car: 1985
Engine: lg4
Axle/Gears: ????????
top speed of 305
what is the top speed of a 305
it is a 1985 camaro
Last edited by woodstock16; Mar 29, 2007 at 10:21 PM. Reason: Automerged Doublepost
Old Mar 29, 2007 | 11:16 PM
Guest
Guest
Posts: n/a
Re: top speed of 305
What engine?
Anyway depending on its state of tune its going to run in the 120-140 range if its basically stock.
Old Mar 30, 2007 | 09:36 PM
woottang30's Avatar
Car: '89 Formula
Engine: 355 SBC, AFR 195s
Transmission: T-56 Swap
Axle/Gears: 7.5 Eaton LSD w 4.10s
My guess is that it is an L03, seeings how thats whats his profile says.
Old Mar 30, 2007 | 10:40 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I got my 86 Trans Am LG4 with carb and intake and T5 up to around 155 or so, using the tach and gear calculator. Took a loooooooooooooooooooooooooong time to get to 5K rpm in 5th.
My 88 Formula does 140+ on a nice long stretch.
70-130 run with stock motor and auto trans,
http://youtube.com/watch?v=BZIeHa-LwaE
Old Mar 30, 2007 | 10:48 PM
jocool's Avatar
Car: 89 Iroc & 88 Firecird & 86 Camaro
Engine: 350 TPI & 305 TBI & 305 Carb
Top speed isn't determined by displacement.
Old Mar 31, 2007 | 12:25 AM
Guest
Guest
Posts: n/a
Originally Posted by woodstock16
it is a 1985 camaro
So that could be an LG4, L69, or LB9. 120-140, +/-
Old Mar 31, 2007 | 12:30 AM
Comp788's Avatar
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
Just because something might go that fast doesn't make it safe to go that fast.
If your going to do a top speed test. Do it in a controled enviorment. Use a helmet and be sure to fully check out your car first. Look at the brakes, suspension, u-joints as well as the condition of the tires.
Maybe even have a role bar or cage.
Old Mar 31, 2007 | 05:57 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
IIRC, GM literature says 138 for the L69.
JamesC
Old Mar 31, 2007 | 12:29 PM
djwimbo's Avatar
Car: 91 camaro T-Tops
Transmission: Borg T5
My L03 91's top speed is 115 (w/ "superchip"). I have a 3.23 rear end and a T5, Mine runs ~3100 or so RPM at the limiter. So there's plenty of gear left, but it's a L03, it runs out of nuts about 110. I hate to assume, but the car in question should have the same axle ratio. Auto or Manual should have different overdrive ratios, so I'm not sure what Rpm's you'll be spinning @ what speeds.
And I agree on the safety factor. Go for it, but don't be stupid about it.
Depending on your O/D gear should be ~140ish
1992 Trans Am
May 10, 2023 07:19 PM
jhawkeye
May 25, 2022 06:33 PM
gta90
Sep 15, 2015 04:00 PM
InfinityShade
Aug 22, 2015 08:00 PM
kyleb24
Aug 15, 2015 08:24 AM
