Camaro doesn't want to "go"...
Old Apr 2, 2007 | 03:14 PM
1990camarogirl's Avatar
Car: 1990 Camaro RS/1992 Camaro RS
I have a 1990 RS with a V6. Sometimes when I'm stopped and then push on the gas it doesn't want to go. It pauses and then jumps forward, similar to someone driving a manual that doesn't really know how. That's the only thing I can think of to compare it to. It's a really random problem, doesn't always happen, sometimes it happens every stop. It seems like a fuel problem but I have no idea where to start to figure it out so if anyone can help me or point me in the right direction I would be so grateful.
I thought I got such a good deal on this car, but it's just problem after problem...
Old Apr 3, 2007 | 12:14 AM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
Re: Camaro doesn't want to "go"...
fuel filter first then go from there
Old Apr 3, 2007 | 11:47 AM
greaser_kevin's Avatar
Car: 92 RS 305, or one of the bikes
Engine: 5.0 L (305 CID)
Transmission: 5 spd Manual
I gave it a full tune up when we bought the car, including the fuel filter. I checked the trouble codes and I get a 33 and a 35. I replaced the IAC valve and there was a slight improvement. But slight is very slight. I am planning on replacing all of her vaccum lines within the next week.
And she forgot to mention it's an automatic.
I know my way around a wrench, but most of my work is on old cars or motorcycles so I would appreciate all the help I can get.
Old Apr 5, 2007 | 10:58 PM
raiders8498's Avatar
Car: 88 Trans Am
i have the same problem buts consistend i cant even drive the car
Old Apr 5, 2007 | 11:11 PM
j dezzy's Avatar
Car: 87 TA
check out the timing. also make sure that your plugs and plug wires are good.
Old Apr 5, 2007 | 11:25 PM
Car: 88 Trans Am
new plugs last week
Old Apr 5, 2007 | 11:32 PM
j dezzy's Avatar
Car: 87 TA
make sure your wires are in good shape. I've you've got headers and don't have the wires out of the way check for burns. Best thing to do would be to use a multimeter and check to make sure they are still good inside. I've recently messed up my engine because I pulled it out of storage and it was running rough and I thought it was just timing, I adjusted that and it got a little better. but soon enough the problem came back. turns out that one of my plug wires was no good and I wasn't firing on the 8th cylinder. the plug wires are too often over looked.
Old Apr 5, 2007 | 11:45 PM
Car: 88 Trans Am
yeah i have msd wire i chaged about 18 month ago but sometime i see the hit the air tubes i guess that can melt some of the rubber
Old Apr 5, 2007 | 11:48 PM
j dezzy's Avatar
Car: 87 TA
Yeah, I've got Accel 300+ 8.8mm wires...and the heat got through one of mine.
Frozer!!!
Jan 19, 2024 04:55 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
Derick15
Sep 17, 2016 05:28 PM
Wylecoyote08
Nov 6, 2015 03:46 PM
