New engine question
Old Apr 11, 2007 | 06:01 AM
devilfish's Avatar
New engine question
Just started my new build engine, and let it idle for around 40 min. Now I have changed the oil and filter. Is it normal to se "soot"/"carbon" in the oil and tiny aluminium "powder" from the oil in the oilfilter? is that from the break in procedure? Not big parts, more like "dust".
Old Apr 11, 2007 | 11:19 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Flat tappet cam, I presume?
If so, what did you use for cam lube?
Old Apr 11, 2007 | 11:58 AM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
Re: New engine question
the powdery stuff is normal when the rings seat to the cyl. walls and from the cam.. but not ALOT of it.. not sure about the carbon..
Old Apr 11, 2007 | 03:30 PM
devilfish's Avatar
Sorry for the lack of info.
Its a hyd roller camshaft. And its not alot, you can se it if you "tilt" the bucket with all the oil in it, is in the bottom. Tiny "flakes" in aluminium color.
I checked the rockers and puch rods for wear but its all fine.
Old Apr 11, 2007 | 05:06 PM
5678TA's Avatar
Car: 1984 Trans Am
yup, its the rings seating and everything else getting nice and happy with each other.. gotta "smooth" things out if you know what i mean.. (didnt mean that in a perv way)
Old Apr 11, 2007 | 06:07 PM
five7kid's Avatar
Either that or an inadequately cleaned block during the rebuild.
Don't run too long before you drain the oil again.
Old Apr 11, 2007 | 10:53 PM
5678TA's Avatar
Car: 1984 Trans Am
i always change oil and filter a few hours after breakin on the engine stand then once again after a 1000 miles.. alot of oil but i dont want shavings in my oil.. i say always because i've broken in my motor 4 times! first build(threw rods), new build(cam down), new cam(cam down), new cam..
Old Apr 12, 2007 | 01:09 AM
devilfish's Avatar
Thanks guys. I will change the oil again after 100km. Good dino oila is cheap
ouch! talk about bad luck
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
