Valve job or new heads?
Old May 12, 2007 | 02:46 PM
magadith's Avatar
Car: 83 Trans-Am (Recarro)
Engine: 305 4bbl
Transmission: 5 speed manual
Hear is my dilema. My valves are going and I kind of want to put new heads on, but I plan on changing the engine in a couple of years from now. So Would it be more affordible to have a shop do a valve job or replace the heads?
Old May 12, 2007 | 03:00 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Valve job or new heads?
What do you mean by the valves are "going"?
Old May 12, 2007 | 04:11 PM
magadith's Avatar
Engine: 305 4bbl
Going bad.
I need to replace my valves in my cylinder head. So should I have someone changes the valves or just get new heads? I figured it would be easy just to change the heads, but replacing the valves would be cheaper in parts.
Old May 12, 2007 | 09:00 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
yes i think we all realized they were going "bad"
what do you mean by bad? what is the car doing to tell you that they are going "bad"?
Old May 13, 2007 | 09:59 AM
magadith's Avatar
Engine: 305 4bbl
When my cars engines cold and I go to start it, the car shoots out a plume of exhaust. I would have to run the car for a few minutes till it stops. And its slowly getting worse.
Old May 13, 2007 | 10:49 AM
Car: 91 RS
Engine: 350 vortec
that means valve seals not new valves i think a set of seals might cost $15-25 much less than new heads
Old May 13, 2007 | 12:13 PM
dv8's Avatar
dv8
Car: 88 IrocZ Vert
Engine: 5.0 TPI
Just to chime in on this one. If the smoke never goes away it could also be cracked/broken ring s on your pistons. But it does sound like valve seals. And you dont even have to take your heads off the engine to change them ( although its alot harder)
Old May 13, 2007 | 12:22 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Originally Posted by dv8
J And you dont even have to take your heads off the engine to change them ( although its alot harder)
it is not any "harder" to do with the heads on the motor. Requires compressed air to hold the valves closed and a simple leverage tool to compress the springs/retainers to get the valve locks out. Not that hard.
About 1 to 2 hours work and a few cold ones.
"shoots out a plume of exhaust"
if the big "plume" is blue the valve seals may be bad or the intake gasket is sucking oil. If the big "plume" is black you need a tune up. Plugs, cap, rotor, wires.
gta90
Sep 15, 2015 04:00 PM
86White_T/A305
Aug 17, 2015 12:16 AM
89mulletbird
Aug 12, 2015 07:08 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
