need help finding fuel pump fuse,,quick
Old May 14, 2007 | 09:54 PM
92rs365hp's Avatar
Car: 2011 dodge journey
Engine: v6 vvt
Transmission: auto
Axle/Gears: ???
I am working on my 91 z28 and cannot find the fp fuse so I can change my filter someone help please
thanks,,,steve
Old May 14, 2007 | 10:03 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: need help finding fuel pump fuse,,quick
how about you just undo the battery?
Old May 14, 2007 | 10:07 PM
92rs365hp's Avatar
Engine: v6 vvt
Transmission: auto
Axle/Gears: ???
trying to keep from spilling alot of gas
Old May 14, 2007 | 10:12 PM
Car: 91 RS
Engine: 350 vortec
if you unhook the battery how will the fuel pump turn on?
make sure to open the gastank before you start loosening fittings
Old May 14, 2007 | 10:15 PM
92rs365hp's Avatar
Engine: v6 vvt
Transmission: auto
Axle/Gears: ???
ok I will unhook bat. but why open gastank??
Old May 14, 2007 | 10:21 PM
Car: 91 RS
Engine: 350 vortec
does your tank ever build up pressure? when you take the cap off does it hiss?
that will force fuel down the line and make a mess
i like to take the cap off so i dont get sprayed... but there is no way around losing gas...
Old May 14, 2007 | 10:22 PM
92rs365hp's Avatar
Engine: v6 vvt
Transmission: auto
Axle/Gears: ???
okie dokie thanks for the tips
steve
Old May 14, 2007 | 10:36 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
For the record, the FP fuse (I think - been a while since I've worked on a stock wiring system), should be on the fuse block in the driver compartment. The FP relay fuse should be up along the passenger side fender (IIRC), by the battery/overflow tank in a weatherpack. Or you could pull the fuel pump relay itself (relay strip on the firewall, by the brake booster - one of the middle relays).
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
Infested
May 22, 2018 11:56 PM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
