First gas smell, then...
Old May 18, 2007 | 10:40 AM
swisscheese's Avatar
Car: '91 Z28
Engine: LB9
Since about a year I smell gas when I stop. It seems to come from the area around the filler neck.
Lately I had the car serviced. On the way to the garage I filled it up, stopped by the garage and noticed a minute later that there was fuel purring down near the axle.
The mechanist told me later that he didn't find anything. all looked well, no rust and stuff. So I left.
Today again I filed the tank, drove about 20 miles and stopped for 5 minutes, when I came back I noticed again some little spot with fuel on the road.
Whats wrong? where should I look first? I don't wan't to loose the car due to a fire or something.
Thanks for any suggestions!
Old May 18, 2007 | 11:13 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Re: First gas smell, then...
Fuel tank vent valve is a one way check valve to let air in.
Issues such as yours are common when they fail and and dont let air in the tank or cause a vacuum in the tank.
Bad canister purge valve usually takes a lot longer to cause issues.
later
Jeremy
Old May 18, 2007 | 03:44 PM
Car: '91 Z28
Engine: LB9
How can I check this valve? I assume that its on the top of the tank. Can I check it from inside or do I need a lift for this and check from the underside?
Twin_Turbo
Mar 14, 2016 10:10 PM
Dwayne614
Sep 29, 2015 11:05 PM
Racerx974
Sep 19, 2015 10:16 AM
earlpote
Sep 12, 2015 11:55 AM
Glowsock
Sep 11, 2015 11:09 PM
