Fuel related problem...im stumped.
Old May 21, 2007 | 09:21 PM
7plagues's Avatar
Car: 92 Precision Red Firebird
Engine: v6->357 vortec xe262h rpm intake
Transmission: t5-> t56
Axle/Gears: 10bolt 3.42s
OK so this is long, i will first describe what was happening.
problem: car would randomly stall for no reason, fuel was not getting to engine. could be 1ft or 1mile of travel...right in there. i drove 120miles between tucson to phx a week before this crap started
info: if i messed with the inline fuel pump fuse it would run a little ways and then stall again.(engine prime fuel i guess would do give it alittle gas)
What i have changed: Fuel filter
Fuel pump Relay
messed with inline fuse(new fuse blah)
New oil pressure switch
New Holly Black inline pump, i just deactivated the old one(left it in tank) and added and piped the Black in by cutting the high pressure rubber hose from the outline right next to the tank and adding more hose into it to the pump, which is sitting just below the tank, upright, about midway back of the driver back seat area, if you know it.
(already had regulator see sig for engine, was v6)
added fuel pressure gauge at the double pumper fuel lines.
Problem now: Engine will run and get 6-7psi of fuel at the gauge and i can drive around for a while and then when i park and check gauge it reads 0psi,all while this "amazing" fuel pump is on. it will slowly charge to 6psi. The problem i have with this is, if i get on it hard for a while the engine will starve for fuel and stall out, then when i re-start it again the gauge will read 0psi and climb back to 6psi. the Fuel pump is running the entire time,and to make sure i ran a temporary switched wired from the battery to the grey wire of the oil pressure switch(goes directly to pump?) and started the engine and got 6-7psi. Drove around about 1-2miles without WOT and parked check gauge while running and it showed 0-1psi....and then slowly slowly climbed to 5-6-7spiked psi while i was parked.
I really need help im tired of spending all this money without results and i need my car for work... and im getting stressed out about this hassle
Old May 21, 2007 | 09:42 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Re: Fuel related problem...im stumped.
I am slightly confused by how you are wording it, but if you are drawing through the old pump, I would drop the tank, remove the old pump, and install a proper pickup.
Old May 21, 2007 | 09:54 PM
7plagues's Avatar
well i've read you can just leave the old pump in deactivated and draw through it with minimal restriction unless your over x-amount of high horsepower
Old May 21, 2007 | 10:06 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Draw through works for some, not for others.
Old May 21, 2007 | 10:48 PM
7plagues's Avatar
yea with the way its goin im figuring thats the reason maybe its getting clogged or something... but if draw thru isnt working for my car why does it still get 5-7psi right off the bat? jw.
Old May 21, 2007 | 10:51 PM
laydebug's Avatar
Car: 1990 Camaro Iroc Z
Engine: 5.0 V8 305
I was having the same problem. I also heard that the pump through works for some and not for others. not enough power to pull through both pumps. we ended up having to change the pump inside the tank. good luck to ya.
Old May 21, 2007 | 11:18 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
What kind of regulator are you using?
Old May 22, 2007 | 12:02 AM
7plagues's Avatar
well the Black pump comes with one, but i have a 3port mallory in there. I was told its better than the one the Black comes with
Old May 23, 2007 | 08:22 AM
7plagues's Avatar
well the fuel pump is getting 12.6continuous volts..
Old May 23, 2007 | 06:08 PM
7plagues's Avatar
well the fuel pump is getting 12.6continuous volts.. so im thinking its definately the old pump which im taking out soon.
Old May 23, 2007 | 09:27 PM
7plagues's Avatar
Quick question, what are the 4 lines goin into the Fuel tank pump? i know its feed, return,....releases air to canister? and something else?
Old May 24, 2007 | 05:35 PM
7plagues's Avatar
hello?
Old May 24, 2007 | 06:01 PM
iroczracer07's Avatar
Car: 1989 Camaro
Engine: 350 but it's torn down right now.
Axle/Gears: I'm working on it,lol.
Is this a carb or fuel injection set up?
Old May 24, 2007 | 09:25 PM
7plagues's Avatar
thanks bud but i got it all fixed now, just took out the pump and made it straight pipe.
Old May 25, 2007 | 08:56 PM
Car: 1989 Camaro
Glad you got it running right.
budofbama31313
Aftermarket Product Review
Sep 16, 2015 12:29 PM
CORV3TT3
Aug 23, 2015 11:26 AM
86IROC112
Aug 21, 2015 07:20 PM
Jk_Under
Aug 17, 2015 03:08 PM
redmaroz
Aug 16, 2015 11:40 PM
