need help with speedometer
Old May 25, 2007 | 09:17 PM
xgtharo86x's Avatar
Car: 86' Trans am
Engine: 85 LG4-non cc carb(building a 350)
Transmission: Rebuilt 700R4,vette servo,2200stall
Axle/Gears: 2.73 Posi
dont no where to post this but this seems like an o.k place.....well my buds 91 v6 rs 5 spd.. speedo is juming all over the speedo will work then just go to 0 as where driving.. then jump back on for a lil... usual turn off when it his 40mph... is the any way to fix this..o and his rpm gauge is broke its stuck on 70 (all the way to the right)..o its a t-5 to
Old May 27, 2007 | 08:12 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Re: need help with speedometer
Pull the dash cluster and check for broken solder joints where the big connector is soldered to the printed circuit board. I had an 88 Grand Prix that had this problem bad. Oil pressure pegged always and another gauge reading right, and then not. You can test for this by pounding on the top of the dash with your fist while driving. I know, this is a little red of the neck procedure, just don't spill your beer during the test ....
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Elephantismo
Feb 13, 2019 12:51 AM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
Bigold4x4
Sep 28, 2015 05:21 PM
