to much flow out
Old Jun 6, 2007 | 08:37 PM
raiders8498's Avatar
Car: 88 Trans Am
to much flow out
smog time came for my car and it has to much flow out out th pcv valve, and the dip stick its just thowing to much smoke i remove the filler cap and its just a constant flow of smoke,I know its the rings but it their something i can do to make it work to pass smog, i was just getting started on building my new motor so i just need the the car to last about 4-5 months, its runs good its just that my plates are out and i cant legaly drive it
Old Jun 6, 2007 | 08:44 PM
blimko's Avatar
Car: Camaro RS
Engine: 305 tbi
Transmission: manual
Re: to much flow out
sawdust.....lol j/k dont put that in there my buddy did that to soften a nock for a sale one time and it sold. im not sure what to tell ya try that engine restore stuff if your sure that your rings are shot and thats where the smoke is coming from
Old Jun 6, 2007 | 09:25 PM
Car: 88 Trans Am
yeah i was thinking about that right know but im not sure
Old Jun 6, 2007 | 10:00 PM
I'd suggest trying an intake gasket first.... they often fail around the heat riser ports, which connects the exhaust right straight into the crankcase.
Old Jun 6, 2007 | 10:06 PM
Car: 88 Trans Am
im not sure which one you mean
Old Jun 6, 2007 | 10:09 PM
The intake gaskets.... between the intake and the heads, where the intake bolts on.
Old Jun 6, 2007 | 10:21 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
come on sofa just show him a picture and be done with it....
Old Jun 7, 2007 | 06:01 AM
Be careful what you ask for, in case you get it....
Old Jun 7, 2007 | 10:58 PM
Car: 88 Trans Am
i just dont see how that will fix my problem when the rings are bad
Old Jun 7, 2007 | 11:32 PM
Car: 91 RS
Engine: 350 vortec
have you done a compression test on the engine? to know the rings are bad?
or are you just guessing because you see some "smoke" in the valve covers
Old Jun 8, 2007 | 12:31 AM
Car: 88 Trans Am
its alot i just remove the filler cap and its just a constant flow
but im just thinking in puting in straight 50 weight and enigine restore or lucas and taking it straight to the smog shop think it will work
Old Jun 8, 2007 | 05:35 AM
How do you know that? They could be, of course; but they're FAR from the only thing that can cause the symptom you describe. Wouldn't it SUCK if you spent $1500 - $2000 fixing a problem that didn't exist in the first place?
The compression test is a good idea. Will tell you right away if you have ring problems.
The way an intake gasket will cause that, is because they can (and quite often do!!!) fail such that they create a DIRECT CONNECTION between the exhaust and the crankcase. Which pretty much describes your situation.
No, I don't think that the thick oil and additives will help, no matter what the cause of the symptom is.
See my signature for some helpful troubleshooting advice.
Pac J
May 17, 2020 10:44 AM
Fireslash
Apr 11, 2016 06:43 PM
jrdturbo
Mar 31, 2016 02:58 PM
dusterbd
Sep 29, 2015 08:40 AM
84redta
Sep 19, 2015 09:58 AM
