91 RS Won't Start
Old Jun 13, 2007 | 11:48 AM
TheCob's Avatar
Car: '91 Camaro RS
Engine: Stock 305 TBI
91 RS Won't Start
It is a stock 91 RS 305 TBI/T-5 with 135K on it. The car ran fine until one day I turned off the engine, go to start it and it turns over, but will not fire. I can smell gas in the TB so I think it is getting gas. I checked the coil and the plug wires and all are sparking. I pulled the valve cover and cranked it over and the valve train moves. I put it at TDC and the No. 1 cylinder valves are both closed.
What am I missing?
I am going to replace the fuel filter tonight and check the pump just to be sure that it isn't a fuel problem. A friend told me that there may be a fusible link at the distributer that could go bad, but I don't know what to look for.
I was going to replace the timing set because it has 135K on it and I wanted to get rid of the nylon crank gear, but it's alot of work especially if it's not the problem.
Any help is appreciated.
Old Jun 13, 2007 | 05:34 PM
TheCob's Avatar
Car: '91 Camaro RS
Re: 91 RS Won't Start
No one?!?!?
Do you need more info? Is this something new or confusing? Am I just a complete TOOL?
HELP PLEASE
Old Jun 18, 2007 | 09:00 AM
TheCob's Avatar
Car: '91 Camaro RS
Pulled the inline filter and cranked the engine over while the filter was off and there is no fuel pressure. Checked the fuse and relay, both are good. I am assuming that the pump is bad. I will replace the pump this week and post results.
Derick15
Sep 17, 2016 05:28 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
EFR2000
Aug 18, 2015 08:54 PM
