Project: Gray Turd. 13 second stock(ish) 305. Pics inside
Old Jun 17, 2007 | 10:57 PM
F-Body Demon's Avatar
1985 Pontiac Trans Am LG4 305 A4
Project: Grey Turd
Purpose: Drag Race
Stock HP: 155
Miles: 105,000
Wieght before project: 3140
Gears: 3.23 stock 9 bolt
Estimated wieght after stripping: 2800
Estimated achieved HP: 275
Estimated Quarter Mile time (calculated): 14.7 @ 8000ft density (that would be 13s at sea level )
Parts removed:
AC system, smog system, headlight motors, front sway bar, wipers and wiper motor, heater core, rear seat and all carpet, exhaust system (minus headers), center console, sterio system, climate control panel, cruise control, front and rear bumpers.
Suspension:
Poly tranny mount and poly torque arm bushing, Edylbrock adjustable torque arm.
Engine:
Hooker 2460 ceramic coated shorty headers running uncapped
Gasket matched Heads, intake, and exhaust
Edylbrock Performer EPS intake manifold
Summit Cam .420 204 Intake / .442 214 Exhaust running 4 degrees advanced
Edylbrock 600 cfm carb
Upgraded HEI Vacuum advance with Malory kit and Blaster 2 coil
Accel plug wires
Heres the catch, if it runs into the 14s. She gets my 406 SBC .
Note the SIR badge lmao
The way the interior used to look
The duo
More stock interior
Head casting number (sorry its upsidedown)
The first piece of progress
Old Jun 17, 2007 | 10:59 PM
Re: Project: Gray Turd. 13 second stock(ish) 305. Pics inside
More progress
Teardown for cam swap
Old Jul 20, 2007 | 07:05 AM
UPDATE!
Intake on, having trouble starting her but oh well.
More on the way, just keeping this updated
Old Jul 20, 2007 | 10:07 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
8000' ?!? You didn't even bump up the compression ratio on that it looks like eh?
I woulda went up to 11:1 or so, it'd run just fine at that elevation.
What's up with the screen on the intake? You been reading some of those "secret" tricks to adding horsepower?
Old Jul 20, 2007 | 12:45 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
would that screen actually pull the fuel out of the air?
Old Jul 20, 2007 | 04:24 PM
cammed91's Avatar
Car: 1991 Pontiac Trans Am
Engine: 350 HSR, Cam, ignition, headers
i think he probably just has it on there during the build up to make sure nothing falls down into the intake/heads.?
Old Jul 20, 2007 | 10:52 PM
Car: 91 RS
Engine: 350 vortec
i was thinking that but it isnt fine enough dirt/metal can still fall in there now maybe some nylons... or just regular tape...
but i guess you couldnt run it like that it would make a pretty good vacuum leak
Old Jul 20, 2007 | 11:14 PM
Sonix's Avatar
Car: 1982 Trans-Am
If he RTV'd it it'd seal.
Someone made an intake manifold gasket that had a screen at each port. The idea was to help "scatter" the fuel droplets, making it atomize better and make more power.
There's a reason very few people (nobody) uses them though, it's total BS.
Just like the magnet on your fuel line, or the tornado, or the electric supercharger.
But there were probably rumors floating around about how great they are so...
The main problem is when it inevitably goes down the tract into the combustion chamber, and does bad things.
I think there are many things that could have been done to get that 305 faster, the edelbrock carb, the weak cam, the stock heads etc, those could all have been improved and you could get a real solid time out of it. Super high compression can be used at that altitude.
I think the july issue of chevy power, or one of those magazines has a letter from a person at 6000' altitude asking about compression due to his elevation. It was a good read, worth looking at.
Old Jul 21, 2007 | 12:53 AM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
The screans do work, put one on my old 305. That motor had HORRIBLE compression, would bog realy bad off idle. The screen helped but killed power above 5k.
Old Jul 21, 2007 | 11:52 PM
netfreak's Avatar
Car: 88 firebird
Engine: 305 TBI
Please kill that SiR badge............. hahaha
Old Jul 22, 2007 | 09:27 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
hate to burst your bubble, but you aint at no 2800 lbs. maybe 3100lbs.
the car needs a 600-650cfm holley double pumper and more intake. that intake you put on there is basically a stock replacement...yep you just waisted your money. i'd have gone with the holley street dominator p/n 300-36. also you'll need more camshaft for your goals. i ran a .442/.465 214*/224* on a 114lsa camshaft with good results. i hope you're planning on putting more gear in it as well. a 3.73 with a mickey thompson drag radial in the 26" height would be a good start.
you also need to put an exhaust system on the car. doesn't have to be anything special, just something to basically lengthen the collector length. the shortie headers will kill exhaust velocity when left open. it really needs a set of hedman longtubes and some torque tubes if you're going to keep it with open headers.
Old Jul 22, 2007 | 10:21 AM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
I'm betting with the carb spacer and stock hood he's not going to have room for an air cleaner (you can see the "hoodprints" in the before picture). The screen is to stop "big" stuff from being sucked into the engine when it's being run without an air cleaner.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
1984HO
Mar 19, 2021 11:59 AM
mustangman65_79
Aug 12, 2015 06:39 AM
antares57
Aug 6, 2015 07:47 AM
