someone stop me !!!!!
Old Jul 3, 2007 | 12:22 AM
iroczz89's Avatar
Car: 1989 irocz convert
Engine: 383 tpi
Transmission: 4 spd auto
I am about to rip my SLP headers off my car and put my manifolds back on if i can't figure out a way to stop #8 spark plug wire from buring!!
Does anyone know if they make a shorter spark plug?? Right now i have the AC Delco R45TS ones and no matter how many heat proof wire shields i use it just keeps burning the boot and causing a miss!
Any help would be greatly appreciated.
Old Jul 3, 2007 | 06:39 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: someone stop me !!!!!
Accel makes a shortie plug. There's also a cross reference attachment somewhere on the boards. If the search function still isn't working just use the google search option for 3rd gen.
Old Jul 3, 2007 | 07:44 AM
I have SLP 1¾" headers on my car; AC Delco Rapid-Fire plugs; Taylor Spiro-Pro wires; no problems of that kind. Or any other kind, for that matter.
http://www.taylorvertex.com/Products...rcatalog10.pdf and http://store.summitracing.com/partde...rt=TAY%2D73051
Old Jul 3, 2007 | 09:11 AM
ad356's Avatar
Car: 1989 camaro rs
Engine: 305 tbi
Axle/Gears: 3.23 lsd swap
taylor spiro pro wires rock. i use them with my edlebrock tes headers no issue, nonwhat so-ever. also you should get valve cover style wire looms. summit sells them, they are by "made for you" products, they are 40 bucks and well worth it.
Old Jul 3, 2007 | 11:27 PM
iroczz89's Avatar
Engine: 383 tpi
I don't have a problem with the wires burning at all just the 90 degree spark plug end for #8 cylinder. Two of the header tubes are too close to the end of the spark plug and that is why it's burrning it and causing an engine miss.
Old Jul 5, 2007 | 04:37 PM
iroczz89's Avatar
Engine: 383 tpi
Here is a picture
Old Jul 5, 2007 | 04:56 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
you need to have your headers ceramic coated. i have the same headers you do and they are Jet-hotted. i hvae no problems. i am using accel shorty plugs, but have run delcos in the past without issue, when it comes time to replace these accels i will use delcos again. the accells are not worth it IMHO.
Old Jul 5, 2007 | 05:59 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
Axle/Gears: BW 9 bolt 3.27
That is an easy fix. Summit carries Accel header plugs that are shorter and you can use different plug wire ends to connect to the plugs. Also, there is a heat wrap you can get for your plug wires to protect them after you do the 2 prevoius things mentioned here. I wish everything was this easy to fix!
Old Jul 5, 2007 | 06:22 PM
Auggie's Avatar
Car: 1984 Z28 Camaro
Engine: H.O. 355 NOS
Yup, I have the same headers and had the same problem. When I installed my Accel 300+ wires I put the pass side wires under the headers like the drivers side and installed NGK UR-5 shorty plugs.
Auggie
Old Aug 26, 2007 | 03:37 AM
The_Phoenix's Avatar
Car: Don't
Engine: have
Transmission: it
Axle/Gears: anymore
hey iroczz89 how do u get that pesky #8 plug out? looks like your plug is in a much tighter spot than mine b/c im running hedman hedders but im still having trouble getting to it! thanks man!
Old Aug 27, 2007 | 12:09 AM
iroczz89's Avatar
Engine: 383 tpi
To get that #8 spark plug in or out i do it from underneath the car. I use a 5/8 box wrench and it goes in as easilly as it comes out. The suggestion of using the accell shorty plugs was the ultimate fix for ease of installation and stopping my boots from burning.
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
sjorgens
Oct 1, 2015 07:54 PM
Luigytico09
Oct 1, 2015 08:46 AM
1HotZ28&SS
Sep 28, 2015 08:58 PM
