Main Caps
Car: 89 Camaro Rs
Engine: 355 build up
Transmission: TH350
Re: Main Caps
i just want to know if they make any stronger ones than stock because i dont want to do the 2 to 4 bolt conversion so i was wonder if there was any aftermaket 2 bolt mains
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Main Caps
Yes, there should be... Have you searched very hard?
A quick check on summit found miloden
MIL-11153
MIL-11153
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Main Caps
You could get "stronger" ones, but the stock ones aren't going to fail, so why waste the money on new caps, and the machining that you'd need to use them?
Car: 1982 Trans-Am
Re: Main Caps
What's the usage of the car? Why do you think main caps are the weak point mlaudon? There are lots of other things to fail before the caps - I think that's what Apeiron is getting at.
[ON] 9 Bolt Axles Partout
6speedIROC
16
Mar 15, 2023 08:33 PM
gta892000
Sep 16, 2015 12:37 AM
