Finally got my combo running!!! Couple questions.
Old Jul 23, 2007 | 10:08 AM
zacharyhorn's Avatar
Car: 91 Firebird
Engine: Turbo 355
Axle/Gears: 3.73:1 7.625" 10 Bolt
I started up my 355 for the first time since the camshaft break in last fall. MAN this thing sounds wild. 4" exhaust sounds great, a little loud but great. Also I couldn't set my total timing because my vacumm advance wasn't working so I'm buying a new canister tonight for my converted points style dizzy. I noticed one thing though when I checked for spark the first time I noticed it was more of a yellow. Does that indicate weak spark? I'm running the stock tbi coil w/ the electronic conversion on the dizzy. Do you guys think that the coil is weak, or is this normal. It ran great, reved it up to 4 grand and sounded good. I just hope maybe its the coil.
Zach
Old Jul 23, 2007 | 12:46 PM
Car: 91 Firebird
Engine: Turbo 355
Re: Finally got my combo running!!! Couple questions.
Anybody have any input? I'm starting to dought the capabilities of the stock coil.
Old Jul 23, 2007 | 01:46 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Converted POINTS style coil?!? Like from a 1973 or earlier car???
With a TBI coil? What a weird combo...
Yea, yellow spark means it's somewhat weak, and or the gap is too far open. I imagine with that ginormos cam you've got a large compression ratio? 10:1 right? You'll probably need to lower your gap to run the stock ignition. Or you can get a hotter coil and module and open it back up. Cooler plugs in there too right?
Old Jul 23, 2007 | 01:53 PM
Car: 91 Firebird
Engine: Turbo 355
The dizzy is a stock dizzy out of a 71 Chevelle. No more points, this conversion kit takes place of the points and it comes with a rev limiter. I am still running my tbi coil, not to weird of a combo I thought. So your saying maybe get a hotter coil? The plug gap is .040, normal. I forget what plugs.
Zach
Old Jul 24, 2007 | 08:54 AM
Car: 91 Firebird
Engine: Turbo 355
Anyone else?
Old Jul 24, 2007 | 09:21 AM
Yellow spark is bad. Should be big fat snapping purple-white. Yes, try another coil. Get the right kind: the HEI coil isn't the right thing for the Pertronix conversion, or any other points conversion (that I know of anyway). It won't work right no matter what.
Vacuum advance isn't part of "total" timing. "Total" timing = static (what you set by twiddling the dist housing) + centrifugal (RPM related, via springs & weights). "Total" is what you get at WOT, and should be right around 36° for virtually any street-driven SBC. Vac adv does not occur at WOT, and is on top of "total". Usually something around 12 - 15° depending on gear, engine size, car weight, and various other things that affect the load the engine sees.
Old Jul 24, 2007 | 10:03 AM
Car: 91 Firebird
Engine: Turbo 355
What would the right coil be for my application, stock the car was tbi and thats the wiring I'm using for the coil. Would this work? http://store.summitracing.com/partde...5&autoview=sku
Old Jul 24, 2007 | 10:14 AM
No; that's a HEI coil. Just a replacement one. But, the same design, wrong for the circuitry you're using to drive it.
You need one more like this. http://store.summitracing.com/partde...rt=PNX%2D40111
mitch_04
Members Camaros
20
Sep 20, 2021 02:24 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
kyleb24
Aug 15, 2015 08:24 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
squiggy2
Aug 9, 2015 09:30 PM
