Max lift for Vortec heads
Old Jul 26, 2007 | 04:54 PM
antman89iroc's Avatar
Car: 89 IROC
Engine: 6.8 HSR N2O
Transmission: TKO 600
Axle/Gears: 9" Moser 3.50 True trac
Hey guys has anyone had any luck with productions vortec's with over 500 lift? Seems like most everyone is saying 480 is about the max. I figured the guide bosses could be machined or retainer/springs would take care of it but ???
Old Jul 26, 2007 | 05:15 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Max lift for Vortec heads
Yes, you can machine them for more lift.
Old Jul 26, 2007 | 08:12 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
That gets you over ~.480", but apparently the ports in stock form exhibit stall at around .530" or so. You can probably port them to get around that, but you'd risk losing the excellent swirl and velocity that makes vortecs so great. If you're going for a big cam, a limited lift racing cam might do the trick.
Old Jul 26, 2007 | 08:51 PM
jonmark1985's Avatar
Car: 89' Pontiac Firebird
Engine: L03 carb Ported #87s new shortblock
Axle/Gears: 2.73 open
This is kind of a poor question to ask. You should find the camshaft you want regardless of lift. Then buy the springs, retainers, and keepers the manufacturer recommends. If your trying to keep factory springs they probably won't have enough open or closed pressure to suit the camshaft you decide on.
Old Jul 26, 2007 | 10:28 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
The Comp Cams beehive 918 springs and retainers will fit with no problems and give you .550" lift without machining. There are other options such as the kit from Crane Cams.
Old Jul 26, 2007 | 11:00 PM
Sonix's Avatar
Car: 1982 Trans-Am
Yea, you'd still have to shim up the valve springs to get .550" lift max with the comp beehives. It's guide bosses that are key, so if you shim up the springs higher, you're good in that respect.
Old Jul 26, 2007 | 11:08 PM
Codename 47's Avatar
Car: 1986 Camaro Z28
Engine: 400
Axle/Gears: 10 bolt Posi 3.73
I did some reading when I got my vortecs and what I gathered was that vortecs really cant be made much better. You'll spend a lot of money and not gain that much. Don't dump a bunch of money into them because after awhile, you're better off buying an aftermarket aluminum head.
What engine are they going on? I've also heard that on a TPI engine vortecs are expensive to set up and aren't all that great.
Old Jul 27, 2007 | 07:48 AM
Car: 89 IROC
Engine: 6.8 HSR N2O
Thanks folks. Here's the deal. I'm currently running a flat top 350 (L98) with mildly ported stock heads, stock TPI, and CC XR264 with .488/.495. Currently getting 237 RWHP and 8.85 1/8 mi. Nice, but I want more... Considering HSR and trying to select a set of heads to match. Right now it seems to be a race between upgraded production Vortecs and Tri-states Tri-Thunder aluminum. OK-duh! But cost IS a factor and the $300 cost differance would go a long way toward the purchase of the manifold. Oh crap! Just writing this made me realize how minor the saving are and. . . Does anyone have any experiance with the Tri-state head???
84z96L31vortec
Aug 20, 2017 12:16 AM
Tinbender59
Mar 17, 2017 10:50 AM
bamaboy0323
Sep 3, 2015 06:07 AM
earlpote
Aug 28, 2015 10:42 AM
L98GTA87
Aug 11, 2015 06:55 PM
