messin with my timing chain
Old Jul 30, 2007 | 01:25 AM
83camaroking's Avatar
Car: 1983 Camaro Berlinetta 1989 RS
Engine: 355 sbc
Axle/Gears: posi 7.5 3.42
https://www.thirdgen.org/forums/imag...ies/crazy.gifI have an 83 camaro and i just rebuilt the motor and i put a new timing chain on it along with other things. Now it wont run or start and i think the timing is off put ive tryed everything but to check the cam and crank timing. i put the dots on the sporkets to the middle facing each other is this correct and any suggestions are appreciated. I miss my car
Old Jul 30, 2007 | 06:06 AM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: messin with my timing chain
yes that is the correct way but after that you need to rotate the crank 360* to bring #1 to tdc firing to drop in your dissy
Old Jul 30, 2007 | 06:20 AM
Damon's Avatar
Agreed. Dot to dot will put you at TDC, compression of #6. If you drop the distributor in and point it to #1 at that point it will be off by 180* at the distributor. Very common mistake.
Old Jul 30, 2007 | 08:17 PM
WhiteHawk's Avatar
Car: 1991 Firebird
Engine: 350,Dart Heads,Weiand In,Roller Cam
Transmission: 2400-Stall, 700R4 w/ Kit
Axle/Gears: 4th Gen 3.42 disc (I wish)
First make sure you are even getting spark. Second make sure you are getting fuel (or even dump fuel or spray brake clean in the intake), still nothing...then.
Turn your engine to #1 TDC with both valves closed (stick something in the plug hole to get your top, whatever you stick in the hole must not knick your cylinder/piston or break off easly). Then make the ignition rotor point at the #1 cap nipple, this is the top of your compression stroke where you want the plug to fire...this is to get the engine running to set timing completely at like 10 BTDC (before top dead center).
If you don't want to remove the valve cover to make sure the valves are closed, then flip the plug wires or rotor exactly 180 degrees on the cap if it doesn't start.
Old Jul 31, 2007 | 04:55 AM
Pat Hall's Avatar
Take your distributor out, turn the pointer on the rotor exactly 180 degrees from where it was, and drop it back in. Make sure to get the oil pump shaft lined up to where it drops all the way back in. It should start after that. Once you get it running, throw a timing light on it, and get the timing fine tuned, and should be good to go. Like Damon said, this is probably one of the most common mistakes. Did that several times when I was a teenager.
Vintageracer
Jan 10, 2020 05:33 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
MY87LT
Aug 17, 2015 08:43 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
