Need a few pictures please
Old Aug 1, 2007 | 08:25 AM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
When I put headers on my girlfriend's '87 IROC-Z, I forgot to put back on two brackets, one looks to be for the power steering pump, but I can't seem to figure out how it went on in the first place. The other bracket I'm pretty sure goes from the a/c compressor to the block, but I couldn't get it to fit because it has to go over the front primary on that side.
If you guys could get me some pictures of the power steering pump bracket and the a/c compressor bracket, possibly on a car with headers, that would be fantastic. Thanks.
Old Aug 1, 2007 | 09:29 AM
joecautela's Avatar
Re: Need a few pictures please
the one photo shows the p/s pump bracket without the alt. bracket. I put the alt bracket on later under the same nut. I didn't put the upper a/c bracket back on. I only put the brace down low below where the air pump goes. If you search for the thread "2055 HKR install pics" you'll find a bunch of photos there. If not I'll go out to the car and take new, better ones for ya, Joe
Old Aug 1, 2007 | 03:52 PM
BlueZee28's Avatar
I tried a few searches but nothing came up. Do you have a link for the thread?
Old Aug 1, 2007 | 06:04 PM
JBeezy53's Avatar
Car: 89 RS
Engine: 350 TBI
Here's the tread, I just search for threads started by joecautela.
https://www.thirdgen.org/forums/exha...-comments.html vbmenu_register("postmenu_3418024", true);
Old Aug 2, 2007 | 09:31 AM
BlueZee28's Avatar
I see it now, although it doesn't show what I'm really looking for. I'm looking for pictures of the front and back sides of the a/c compressor and the power steering pump. I need to know how the brackets go on.
Old Aug 2, 2007 | 09:52 AM
joecautela's Avatar
hang out about 20minutes or so. I'll go out and take a few more and scan them in
Old Aug 2, 2007 | 10:09 AM
joecautela's Avatar
I hope this helps. the p/s bracket is a short piece about 4" long. The pump end is notched so it just slips under the bolt on the pump. The other end fits on the 1st stud on the head. There is also a second bracket that bolts from the alternator to the same stud. On the A/C side I left that bracket off. I did put the lower support in from the bottom where the air pump used to be. That section is so solid there just isn't any vibration
Attached Thumbnails Need a few pictures please-alt-brackets-003.jpg   Need a few pictures please-alt-brackets-004.jpg   Need a few pictures please-alt-brackets-005.jpg
Old Aug 2, 2007 | 10:12 AM
joecautela's Avatar
here's 2 more, I don't know if they'll help but here they are
Attached Thumbnails Need a few pictures please-alt-brackets-001.jpg   Need a few pictures please-alt-brackets-002.jpg
Old Aug 2, 2007 | 11:49 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
https://www.thirdgen.org/forums/tpi/...-pictures.html
If you have a V-belt setup these may help.
With headers you will need the spacer and the top bracket on the A/C may need trimmed to fit the tube.
HTH
Fronzizzle
Feb 9, 2017 09:31 AM
Linson
Sep 21, 2015 01:08 PM
okfoz
Sep 17, 2015 10:30 AM
Street Lethal
Sep 7, 2015 01:09 PM
Strick1
Sep 6, 2015 02:21 PM
