383 with 224/230 or similiar cams inside please...
Old Aug 4, 2007 | 10:58 PM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
What kpa are y'all idling at...just curious for idle tuning reasons....I don't have a data cable at the moment but I can adjust the values around it.....I believe it to be about 50-55 kpa b/c I've seen A/F ratio differences changing the VE there with my wideband. Thanks for the input!
Old Aug 5, 2007 | 08:29 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: 383 with 224/230 or similiar cams inside please...
I'm still tuning but my kpa is usually between 55 and 57 at idle.
btw - i'm 350 with 224/230
Old Aug 5, 2007 | 01:54 PM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Thanks for the info. I might be a little lower than I thought then....probably 45-50. I have the XFI grind instead of the XE grind though...little more aggressive.
Old Aug 6, 2007 | 07:19 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Mines's a custom XFI.
Old Aug 6, 2007 | 12:41 PM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Awesome....me too!
Old Aug 10, 2007 | 05:50 PM
kaylin4u's Avatar
Mind is 58-65 kPA.
I'm running a HSR with a 383 and Speed Density.
Old Aug 10, 2007 | 05:58 PM
89formula350b2l's Avatar
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
Originally Posted by kaylin4u
Mind is 58-65 kPA.
as am i! mods in sig
Old Aug 10, 2007 | 11:24 PM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Our combination is very similiar except I have the XFI grind. But very good info.....do you have a .bin file that I might can look at....I have a fuel stumble about 1400-2000 I can't seem to clear up.
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
gixxer92
Sep 1, 2015 04:32 PM
lt1z350
Aug 28, 2015 05:57 AM
bdads
Aug 24, 2015 06:01 PM
LT1Formula
Aug 20, 2015 09:36 PM
