Please need help BADLY
Old Sep 1, 2007 | 03:01 AM
tigercyberslash's Avatar
Car: 1984 Camaro Z28
Engine: V8 350 ci
Axle/Gears: Posi, Disk brakes all the way aroun
If anyone can help i would be truly thankful, Our daily driver is having some problems, 1997 ford escort v6 manual, When at a light , the car wants to die, like its not getting enough gas and wants to die. When in neutral it does the same thing. Just started doing this yesterday, please advise as my camaro is not in driving cond. and i need this car to be working. Any help would be great!
Old Sep 1, 2007 | 04:18 AM
TPI's Avatar
Car: '89 Trans AM/'88 GTA
Engine: (2) Tuned Port L98's
Re: Please need help BADLY
Fuel pressure check is the only way to know if your
getting enough fuel to the injectors, and maybe a
quick fuel filter swap.
Any engine light during this period and does it stall?
smoke from the tail pipe? Can it rev to a higher rpm?
It's not a 3rd gen related, so ..I dont know how far
this will go.. but, I thought Id help.
Good luck
Old Sep 1, 2007 | 04:23 AM
TPI's Avatar
*Double post whoops*
Old Sep 1, 2007 | 06:48 AM
Cflick's Avatar
Car: 87 Suburban 2500
Engine: 455 Wildcat ( somewhat modified ))
Transmission: TH400 ( for now )
Axle/Gears: 4.10 ( for now )
Pretty much every time I've seen this, especially if it otherwise runs normally, it's been a flakey throttle position sensor.
Old Sep 1, 2007 | 07:00 AM
battyice's Avatar
Car: 1985 Z28
Engine: 355 topped with Dart heads
Axle/Gears: Stock axle with 3.73's
Does it run alright if you open the throttle a little bit? If so, I would suspect that the idle air control valve needs to be replaced.
Old Sep 1, 2007 | 11:53 AM
Engine: V8 350 ci
No it doesn't smoke at all, the engine light comes on but only when it dies on the road. It revs fine, it doesn't have any problems when I'm driving on the freeway only when I'm at a light or in 1st gear. Seems to switch normally and the clutch is okay.
Old Sep 3, 2007 | 01:13 PM
Cflick's Avatar
Have you pulled codes from the ECM ?
Old Sep 3, 2007 | 01:31 PM
Engine: V8 350 ci
No haven't done that...I kind of remember how to do it on my Camaro but can someone remind me how it's done?
Old Sep 3, 2007 | 01:46 PM
Cflick's Avatar
Don't remember on a Ford, but Autozone has a pamphlet and a "key" that'll tell you how.
Free, as I recall.
Old Sep 3, 2007 | 08:04 PM
rick89formula's Avatar
Car: 89 formula 350
Engine: 5.7L (L98)
Transmission: 700R4-(shift kit,corvette servo)
Axle/Gears: borge warner-3.27
Definately check your pcv tubing. These are very prone to getting a hole in the rubber of the tube and causing a vaccuum leak. This will cause very eratic idle but do ok at higher idle or driving at higher speeds. I work at a shop and I see this quite often. I would even bet that Ford would have this part in stock for around $20-$30. Look at the line itself and right at the rubber boot at the pcv valve you will probably see the boot caved in and maybe even ripped. This would be your problem. Good luck and let me know how it goes. .
Old Sep 10, 2007 | 08:56 PM
Engine: V8 350 ci
Just went out there today to try to do an oil change, and started up the car to listen under the hood cause it had been making a hissing noise and well you were right, I found the tubing and it does have a hole in it! Thanks for the help, I don't know why I wasn't able to find it the first time I looked at it!
Old Sep 11, 2007 | 12:38 AM
duckmanquacker's Avatar
Car: 84 Z28 / 88 Trans Am / 87 base
Engine: L69 H.O. / 468 BBC / 2.8 v6
Transmission: 89 700R4 / TH375B / 700R4
Axle/Gears: 3.73 open / 3.23 posi / 3.42 open
because it was a ford and not your chevy
Old Sep 11, 2007 | 01:04 PM
GTA Jim's Avatar
Car: 1990 GTA
Engine: 5.7
Transmission: 4L60
Axle/Gears: 3.27 Posi
The 1997 Escort never came with a V6.
If you have more troubles, you'd probably get a better response posting your question on a forum dedicated to Ford Escorts.
http://www.feoa.net/modules.php?name=Forums
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
3rdgenkindagal
Aftermarket Vendor Review
25
Oct 21, 2015 09:32 AM
L98GTA87
Oct 19, 2015 10:43 PM
dimented24x7
Sep 17, 2015 06:58 AM
gta892000
Sep 16, 2015 12:40 AM
