Question for all 383 owners????
Car: 1991 Gta trans am
Engine: 383ci,trickflow alum. heads, hsr
Transmission: T-56, alumin. driveshaft
Axle/Gears: stock 7.5"/3.42
What way did you guys have your motor balanced??? Like was it an external crank, with netural balance flywheel?, and an external dampener? or was everything externally balanced...??? I am asking because I had my motor internally balanced and it seems the crank broke on me....and I think it was because of the way I had it balanced.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Question for all 383 owners????
Mine is externally balanced. Your balancing didn't have anything at all to do with the crank breaking.
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
the crank probably had a small crack, whick turned into a big crack
Where did it break; where they always do, at one end (most often the front end) of the pin for the #1 & #2 rods?
If so, balancing had NOTHING WHATSOEVER to do with it. About the only thing that can stop that, is using a better crank damper than stock. NOT a Fluidamper or a Rattler or a chinesium one like a CAT; the only one that's anywhere near dependably effective is the ATI.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
"pin" for the #1 and #2 rods? What pin is that?
Car: 1982 Trans-Am
I would be safe calling that the cranks front rod journal eh? I just want a mental picture of this.
oh ok well that gives me reasurance that it wasn't because I went internally balanced...I was just trying to figure out why it broke, but you guys cleared that right up so
for your help and I only hope that my luck gets better this next time around. lol
for your help and I only hope that my luck gets better this next time around. lol Joined: Sep 2005
Yeah my little bro keeps a piece of one of my old 400 cranks, that broke off right there.... it sits on his coffee table, looking like a cast-iron pancake with a wart, just the front "throw" of that #1 journal, the counterweight, and the snout.... like I said, pretty typical. I was running a stock damper on that motor, too, just like you I guess.
Here's my past two advetures
