engine size problem
Old Sep 22, 2007 | 12:48 AM
master2090's Avatar
engine size problem
i just bought an 85 iroc with what i was told was a 350 v8 in it(that was supposidly recently rebiult) and it even has a badge on the rear bumper that says 5.7 tuned port injection. i have been doing some research that has told me there was no 85 350 except a couple sites. is there such a thing as an 85 iroc with a 350 or did i get majorly miss-informed.
Old Sep 22, 2007 | 01:26 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: engine size problem
I think the '86 year had the first 350s, and only about 86 of them as well. ULTRA RARE. Also, '85 didn't have tuned port. He just added the badge, and maybe pulled an engine from a (say) 1988 Camaro, rebuilt it and dropped it in.
Get a picture of the engine and we can tell you if it's tuned port, and if you get the casting number off the block when can tell you if it's a 305 or a 350 engine.
Old Sep 22, 2007 | 12:36 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
1987 was the first year for the 350, all the 350 test and promo cars built in 1986 were destroyed with none sold to the public. TPI was first available in 1985 on the 305.
Old Sep 23, 2007 | 02:39 PM
master2090's Avatar
yeah i have been told a couple times the original 305 might have been replaced
Old Sep 23, 2007 | 02:41 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
The original 305 motor may have been replaced with a 350. You would have to check the block casting number.
Old Sep 23, 2007 | 02:44 PM
master2090's Avatar
yeah i found that most sites said 86 was technically the first year. it says tuned port injection right on the engine so i know thats right, but where would i find the casting number on it cause i have looked and i cant seem to find it.
Old Sep 23, 2007 | 03:11 PM
Sonix's Avatar
Car: 1982 Trans-Am
check www.mortec.com they've got some info to help you.
You'll want to look at the rear decks, right in front of the tranny BH area. Or the TC cover area. It's not easy to get to, so have fun
Old Sep 23, 2007 | 09:57 PM
master2090's Avatar
ill have to check out the site and see what i can learn from it, thanks. oh and ill definatly have a good old time searching for it
NinjaNife
Aug 23, 2015 11:49 AM
Linson
Aug 21, 2015 02:12 PM
zeitghaist
Aug 18, 2015 07:33 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
knight72
Aug 10, 2015 09:32 PM
