what about this combo?
Old Sep 24, 2007 | 06:50 PM
Dainius's Avatar
Car: 1990 RS
Engine: 305 carb
Transmission: 700r4 with transgo shift kit
Axle/Gears: ?? not sure yet just got the car
ok Ill try and make this short. Ive got a 350 block casting 14016379, 305 tpi heads from i believe an '90 that have been rebuilt with new springs and so on and so on. Motor was rebuilt last year with all original parts(not sure if its a 4 bolt yet) and I have a crane cam with these specs: bear with me i know nothing on cams. adv duration 260 int 260 exh, cam lift int .2847 exh .2847, valve lift int .427 exh .427 lobe ctrs. 105 int 115 exh and .050 dur? like i said i hope that helps. I have an edel performer rpm intake, 3 inch catback with headers, new rods,lifters, edel 1406 carb and a 3 way afpr. I wasnt sure if this might be a good combo till i build up my 383. Im replacing my shot 305 so Im hoping this will be a drastic improvement over that piece. thanks for reading
Old Sep 24, 2007 | 11:22 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: what about this combo?
That'll work I guess. It'll be very mild, watch your compression with that teeny street cam and a 350 with 305 heads. If the 350 was truly done to stock specs it's got 1.54" Compression height pistons, with a 12cc dish, and you're fine - but just make sure.
It will be drastically better than a shot 305 it should run
Old Sep 25, 2007 | 06:53 AM
Dainius's Avatar
Car: 1990 RS
Engine: 305 carb
yea i was kinda worried about this cam... any suggestions on a good cam for this combo? as I mentioned earlier I have no idea about cams whatsoever...I hear alot about the xe268 i believe? is that a good choice?
Old Sep 25, 2007 | 10:16 AM
Sonix's Avatar
Car: 1982 Trans-Am
First find out the specs on the engine, otherwise you're just shooting in the dark. Find out what pistons are in it, if it was decked (how much?), etc. Are you porting the heads? (you should). Then, i'd most likely recommend the xe268, it's working well for me so far.
Linson
Oct 24, 2025 02:00 PM
InfernalVortex
Apr 20, 2021 11:31 AM
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
roysatikas
Sep 22, 2015 08:15 PM
z28guy134
Sep 1, 2015 11:50 PM
