flaring fuel lines
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
flaring fuel lines
what is probably the best flare to use on a stock metal fuel line? I cut my stock metal fuel lines back by the firewall so I can flare them and adapt to AN braided steel fuel line so I can just run it up behind the engine along the firewall to the fuel rails of my engine. No reason to have them come up from the front drivers side like it does stock with a completely aftermarket efi engine.
I am looking for a much cleaner look.
I could do inverted flare like I did to my brake lines perhaps?
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: flaring fuel lines
If you're using AN fittings, it makes more sense to use an AN flare.
Car: '02 Z06
Engine: L33 5.7
Sucks the search is broken right now.
Did not know a tube flare tool for AN fittings existed. I am not having any luck finding it on summit unless its one of the 37 or 45 degree ones. What kind of tube bushing would I use?
Car: '02 Z06
Engine: L33 5.7
for the nut and sleeve, since its only AN sizes of coarse, Should I run a -6 and an -8?
or am I mistaken on which nut is going to fit my stock lines which are 3/8 and 5/16 I believe.
also, I am looking at the sleeves, where the heck do they go?
Engine: 383 Carb
Transmission: 4L60
The stock lines are 3/8" and 5/16", so you'd use -6 and -5.
The sleeve supports the back side of the flare. The nut goes on the tube, then the sleeve, then the line is flared and the sleeve and nut are pushed up to the end.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
they also make compression type AN adapters that dont need flaring. only for 3/8 and 1/2 line though
Jegs #555-100551, 555-110550, and others depending on flavor
Car: '02 Z06
Engine: L33 5.7
Today I recieved all my AN fittings and flaring tool, Should be tackeling the job in the next week or so, I will let you all know how it works out. thanks!
theshackle
Mar 5, 2017 06:37 PM
ambainb
Apr 25, 2016 09:21 PM
AkDrifted
Aug 17, 2015 07:45 PM
