Tpi intake to Ls1orLs6 intake
Old Oct 2, 2007 | 05:25 PM
firebird896's Avatar
Car: '89 GTA/'86 TA/98 TA
Engine: 350/350/LS1
Transmission: R4/T5/4L60E
Axle/Gears: 3.23/2.77/3.73
Is swaping that hard to do or is it an entirely different setup all together
Old Oct 2, 2007 | 05:27 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Tpi intake to Ls1orLs6 intake
cant put a LSx intake on a TPI motor
Old Oct 2, 2007 | 05:36 PM
Engine: 350/350/LS1
not at all? Can you put a camshaft from an LSx in a tpi engine
Old Oct 2, 2007 | 05:38 PM
327???'s Avatar
Car: '82 Sport Coupe/'89 bird/'77 280z
Engine: 355/2.8/L28E(t)
Transmission: TH350/T5/4 spd
Axle/Gears: 3.73/3.42/3.54
No, do you have a lot of LSx stuff?
Old Oct 2, 2007 | 06:05 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
most lsx stuff wont fit TPI engines...cept the fuel injectors i understand
Old Oct 2, 2007 | 07:06 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
..and maybe the roller lifters.
Old Oct 2, 2007 | 10:24 PM
Guest
Guest
Posts: n/a
The LSx engines are pretty much entirely different animals than the SBC.
Cant use the cam. Bearing diameters are different, firing order is different, and most importantly the order of intake and exhaust are completely different. The spacing and length may also be different, but doesnt much matter. Cant use it. Or the crank, pistons, heads, headers, and a number of other items.
Old Oct 3, 2007 | 01:09 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
An LS1-style engine is more different from a small block Chevy than a big block Chevy is.
Old Oct 5, 2007 | 10:33 PM
Engine: 350/350/LS1
What kind of upgrades could I add then
Old Oct 5, 2007 | 10:38 PM
Kevin91Z's Avatar
Read the tech articles, the FAQ, the tech data, learn something from them, and then ask if you dont know. There are a million things you can do to a thirdgen, exhaust, suspension, intake manifold, headers, cam, heads, interior, audio, its unlimited.
LT1Formula
20
Nov 14, 2015 12:02 AM
masonta
Aug 31, 2015 10:14 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
