Slave/master cylinder help Please!!!
Old 10-20-2007, 09:49 PM
IROCaholic's Avatar
Car: 89 Camaro RS
Engine: 350 carbed now
Transmission: World Class T5
Axle/Gears: Peg Leg w/ 3.73's
Ok, I posted this on the transmission board last week and did not get a response so please someone help! I just finished swaping out my 700r4 for a wc t5 and I have everything up and running except the master cylinder and slave cylinder. The pieces from gm come hooked together with a hard line, however the auto parts store sells them seperate and without any threads or fittings to hook a like up to them. So how are you guys hooking them up? I tread thread a fitting in the master, but its made of plastic so it cracked Any help would be appreciatted and if you guys have any pics of what you did that would be even better. Thanks.
Old 10-21-2007, 10:48 AM
squirted1's Avatar
Car: 84 Trans Am
Engine: 383
Transmission: Tremec TKO
Axle/Gears: 10 bolt 3.73 lsd
Re: Slave/master cylinder help Please!!!
the master/slave assm from gm is complete and pre bled, it is installed as a unit. the master and the slave are available from parts houses but the hard
plastic hose usually is not. the hose is sealed by an o-ring and retained by a
roll pin. trying to thread in fittings into the plastic will result in what you have already discovered.
Old 10-21-2007, 03:45 PM
IROCaholic's Avatar
Car: 89 Camaro RS
So, the only way to do it is by getting the factory line? thanks for the help.
Old 10-21-2007, 04:22 PM
IROCaholic's Avatar
Car: 89 Camaro RS
Does anyone know if a 4th gen assembly will work? I can get one from a 93-97 car pre-assembled.
Old 10-21-2007, 04:31 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
NO it will not work
Old 10-21-2007, 06:24 PM
IROCaholic's Avatar
Car: 89 Camaro RS
Nice! Well I appreciatte the input, I will just have to figure out a way to get the factory line.
FormulasOnly
07-23-2018 08:47 AM
Cam-aro
Camaros Wanted
11-12-2015 03:35 PM
meeklay812
10-01-2015 03:46 PM
usafirebird
09-29-2015 11:58 PM
Badass355ciz28
09-28-2015 08:31 PM
Quick Reply: Slave/master cylinder help Please!!!
