Computer/ECM swap
Old Oct 25, 2007 | 04:50 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Computer/ECM swap
The ECM in my car has the serial number 1227615. The car is an automatic with a 305 TPI in it. Will a computer from a carb'd motor or a car with a manual transmission in it work? Would it be worth buying a ecm with the same serial number and switching the PROM in it if necessary or would it be a better idea to find one with the right PROM in it?
Old Oct 25, 2007 | 07:05 PM
Vader's Avatar
Re: Computer/ECM swap
The number you need to find is a Service Part number, not a serial number. Any ECM with the same Part Number can be used and your PROM can be installed to make it functional in your car. Most of the 1985 305 TPI engines used the 1226870 ECM.
Old Oct 25, 2007 | 08:37 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I believe what you're asking is if you take an ECM from a carb'd car if it will work in a TPI car.
I'm no #'s expert, but I doubt that would work.
Old Oct 25, 2007 | 09:17 PM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
'85IROC
Carbed ECM (CCC) will not work in TPI harnesses car. There are too many differences to list. Also, are you sure that you copied ECM service number correctly??? 1227615 - it maybe an odd ball service replacement number.
//RF
Old Oct 26, 2007 | 06:11 AM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Yes, i know i have the right number. The motor is not out of an 85 in my car, somebody changed the motor in the past and put one from a 1988 in it so that is where i got that number from.
Old Oct 27, 2007 | 03:03 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The last digits should be 7165, that is the correct code for an 86-89 TPI MAF computer.
Old Oct 28, 2007 | 05:06 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Is the 1227615 ECM the only one i can use or would another one work? Would a computer with O.E # 16198445 work? How about taking a computer out of a car that has the same number on the ECM even with it not being a camaro and just switch the PROM out?
Old Nov 6, 2007 | 06:06 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
I found an ecm with #1227619. Mine is supposed to end in 165. What would be the difference between these two? Would they interchange?
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
jharrison5
Aug 19, 2015 05:53 PM
355sbcTPI
Aug 19, 2015 04:38 PM
