2 piece RMS Crank in 1 Piece RMS Block?
Old Oct 27, 2007 | 04:07 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I am in the process of building my 355 and a friend of mine has a brand new 383 kit that he is selling me for a really good price, but we found out it is a 2 piece RMS crank.
I was looking to see if I could use that crank in my block and I found this part,
http://www.superchevyperformance.com...17&Search.y=13
That part also requires these parts as well,
Note: Use rear seal P/N 10121044, retainer gasket
P/N 12555714, dowel pin P/N 9441003, and
1986 or later oil pan and gasket set.
But I can't find prices for them.
anyone here ever did this kind of RMS conversion?
My block is already bored .030 over, cleaned, and has the cam bearings installed, so I have about $250 already in it.
EDIT: found an older thread that has the Scoggin Dicky part, but still no reviews of either of them,
http://www.sdparts.com/product/SD100...Chevrolet.aspx
Old Oct 27, 2007 | 07:18 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: 2 piece RMS Crank in 1 Piece RMS Block?
I just read a thread a couple of days ago about someone who bought a crate engine and noticed that even thought it was a 1 pc block, it had a 2 piece crank and his flexplate wouldn't line up.
Somoene responded that the 2pc cranks are cheaper and it's more cost effective to use an adapter.
I know it doesn't help a whole heck of a lot, but if you can source the parts, it shouldn't be that expensive, since it's apparently a cost-cutting method for crate engine builders.
Edit: here's the thread
https://www.thirdgen.org/forums/tech...ine-1-2-a.html
MoJoe
Sep 24, 2015 09:12 PM
Steven 86IROC-Z
Car Audio
16
Sep 7, 2015 08:05 AM
Reborn756
Sep 4, 2015 03:42 AM
91REDZ28VERT
Fabrication
Sep 3, 2015 02:28 AM
gixxer92
Sep 1, 2015 04:32 PM
