my engine will shut off
Old Nov 1, 2007 | 07:27 PM
3genLT-1's Avatar
my 92 z28 will shut off on me while driving, the only thing i can see that could be the problem is the rpms, which will drop below 500 while braking and will kill the car. i lose power steering and will have to pul off the road to put the car into park and to restart the car. i thought it was a heating problem so i replaced the thromstate with a 195 but the tach will still read well above that. any ideas to what my problems are?
Old Nov 2, 2007 | 07:26 AM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: my engine will shut off
When it dies, does it start back up right away?
Do you smell gas when it dies?
Old Nov 2, 2007 | 10:57 AM
3genLT-1's Avatar
yes i can start it back but i have to stop the car. i dont smell any gas it feels electical
Old Nov 4, 2007 | 06:51 AM
If you think it is electrical, I would check the control module under the distributor cap. Also, check your TPS sensor to make sure there isn't any dead spots at the lower voltages.
For non-electrical, it could be a lot of things... clogged fuel filter, bad vacuum leak, failing fuel pump, failing injector(s), etc.
Hope this helps!
Best of luck.
Old Nov 4, 2007 | 07:29 AM
gapimpin's Avatar
Car: 1991 Pontiac Firebird
Engine: 383 LT1
Transmission: built 700r4 and fuddle 3500stall
Axle/Gears: 4th gen 3.42 auburn
why not just throw it in neutral and start it back up? i know its not a fix but pulling off the road while you have no brakes and no power steering is dangerous. i put my car into a pole that way in high school.
Old Nov 4, 2007 | 04:11 PM
royslsbry's Avatar
Car: 1992 RS
Transmission: 700r
check your fuel pressure first and see how it is
Old Nov 4, 2007 | 04:36 PM
3genLT-1's Avatar
thanks everyone I found one of the bolts to the TPS was stripped out and letting the TPS move around
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
wayshegoes
Aug 17, 2015 12:00 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Fronzizzle
Aug 9, 2015 01:15 PM
