starter issues
Old Nov 2, 2007 | 04:12 PM
racerd146's Avatar
Car: 92 firebird
starter issues
the starter on my v6 firebird when its cold spins but dose not engage the flywheel then wait a second and it engages the flywheel starts right up and other times it will engage the flywheel turn the motor over then just spins with out turning the motor over. could the bendix be dirty or defective it dose not seem like the fly wheel is missing teeth
because you wait for the starter to stop spining then it fires right up no problem, any thoughts
Old Nov 2, 2007 | 05:26 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
Re: starter issues
yea replace the starter lol
Old Nov 2, 2007 | 09:05 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: starter issues
Or just the solenoid if you're frugal.
Old Nov 3, 2007 | 03:07 AM
racerd146's Avatar
Car: 92 firebird
Re: starter issues
im not so much frugal id rather just build it than buy it, so the solenoid is whats wrong?
Old Nov 3, 2007 | 09:07 AM
jv9999's Avatar
Engine: 5.7L/350
Re: starter issues
Most likely. That's what moves the pinion to engage the flywheel. It may just need a good cleaning and a little grease.
Old Nov 4, 2007 | 06:02 PM
racerd146's Avatar
Car: 92 firebird
Re: starter issues
the solenoid was 9 bucks cheaper than the starter itself and thats what was bad and now i have a low esc voltage
or esc circut problems?
edit: i figured it out
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
TheTraut88
Sep 11, 2015 05:16 AM
TheTraut88
Sep 7, 2015 05:22 PM
TBRays98
Sep 6, 2015 05:05 PM
greenyone
Sep 2, 2015 03:39 PM
