Which Cam
Old Nov 9, 2007 | 02:22 PM
zapr's Avatar
Car: 1985 camaro z28
Engine: 305 lg4
Which Cam
.........It's been a while since my last post but always on here reading. It's time for a cam! My car is an 85 z28 LG4 auto. Canadian car so no computer. 9.5:1 compression. Car is stock and I'm keeping the stock heads. To the best of my knowledge, I have 3.08's. At WOT it shifts into second at 35 mph if that's any help. I have a high flow cat and a 2.5" dynomax catback but stock manifolds and y-pipe but considering headers and a full 3" exhuast. After researching the boards I'm leaning toward the xe256. What can I expect with this cam? What will happen to low end torque compared to the peanut cam? Should I consider the xe250? Thanks for any help......Zapr.
Old Nov 9, 2007 | 03:47 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Which Cam
The xe256he is a great bet for you. Don't bother with the 250, I don't even think the 250 is in the xe line, I thought it's a high energy straight pattern? Anyway, the xe256 won't kill low end or anything, it'll only help things.
I'd upgrade the valve springs while you're there. I might also look at a bigger stall speed on the converter. Not so much due to the bigger cam, but just because it's sleepy stock - might as well go up to 2400RPM or so.
Old Nov 10, 2007 | 12:31 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
If you're going to do exhaust and higher stall converter, you might as well go for more cam. The XE268 is a great street performance cam.
Ditto the valve spring upgrade.
Old Nov 11, 2007 | 12:29 AM
zapr's Avatar
Engine: 305 lg4
Re: Which Cam
.......Ok. Would I be able to use the stock push rods with either of these cams? If not, would I have to use a different length? I was also wondering about discharging the a/c to remove the condenser. Is that something I can do myself, or should I have a professional discharge it? Thanks for the help........Zapr.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
