Ramjet cam in a lo5 with #113 heads?
Old Nov 14, 2007 | 02:51 AM
BDKerr11's Avatar
Car: 86 Transam / 80 Transam
Engine: 86/355 lo5 80/68' GTO 400
Transmission: 86/700R4 80/TH400
Axle/Gears: 86/3.42
I got a lo5 reman. roller long block for $1000 and changed the heads out with some reman. #113 allum. D-port heads I bought for $400. Tryin to decide on a cam. I Siamesed my TPI intake approx. 2.5 to 3" Ive heard you can lose your lowend torque doing this. The car will mainly be street driven with an occasional trip to the track. I really like the the specs on the Ramjet cam and can get a new one cheap. Is this a good choice for my heads and to retain some low end torque? With my 1.6 rockers the max lift will be like .481. I know the 109 lsa will be hard too tune also which shouldn't be a problem for me. Or should a go with a different cam? Thanks for all your replies.
Old Nov 15, 2007 | 12:40 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Ramjet cam in a lo5 with #113 heads?
The Ramjet cam is tiny. Go for an LT1 camshaft instead.
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
MoJoe
Sep 24, 2015 09:12 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
anesthes
Aug 8, 2015 09:37 PM
