Mist Water in Engine to Steam Clean it?
Old Nov 14, 2007 | 06:29 PM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
So you rev your engine to 3k or so, then mist water into it...
The water turns into steam, loosens carbon and deposits by "steam cleaning", black smoke exits tail pipe... repeat every 30 seconds or so...
I've heard about this many places... I've also heard about GM Top End Engine Cleaner....
So has anyone done this with good results or bad?
I have a TPI, should I?
Any other products I should look at???
Raf
Old Nov 14, 2007 | 06:38 PM
NicksToyTA's Avatar
Car: 89 Trans Am... 92 25th RS
Engine: TPI 350 .03 over ported lower&bowls
Transmission: 700R
Axle/Gears: 2:73
Re: Mist Water in Engine to Steam Clean it?
I used to do that with great luck on carbed and tbi engines. Never really had one of my tpi engines get bad enough deposits to go to the trouble but i dont see any reason it would hurt.
Old Nov 14, 2007 | 06:44 PM
royslsbry's Avatar
Car: 1992 RS
Transmission: 700r
you can try some seafoam
Old Nov 14, 2007 | 06:49 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
It works fairly well, but its also a quick way to plug up a cat.
Old Nov 14, 2007 | 06:50 PM
luvofjah's Avatar
Seafoam & TPI.... how?
Raf
Old Nov 14, 2007 | 09:06 PM
Vader's Avatar
Seafoam? You might as well roll up a $5 bill and set it on fire. Get a gallon of windshield washer solvent for about 79¢ and do some real cleaning. The methanol in the washer solvent will clean a lot better than the isopropyl alcohol in the Seafoam. The rest of the solvent is waer and blue tint, and the water will clean a lot better than the 10% water in Seafoam. Use a small (about 5/32") vacuum line and adminster the washer solvent through engine vacuum. 3,000 RPM isn't necessary. Just keep it at a high idle to about 2,000 and let it ingest the whole gallon. Make sure the engine is at full temperature before you begin.
Old Nov 14, 2007 | 10:17 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
BG sells a great product which many mechanics use to clean intakes, fuel injectors, etc etc. they do have their own machine to create a fine fine mist at a certain pressure depending on engine. ive used it on many cars and it cleans them very well, as you can see all the buildup exiting through the exhaust once it starts cleaning.
Old Nov 15, 2007 | 12:40 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Amazing what the search feature brings up...
https://www.thirdgen.org/forums/tech...ter#post156162
https://www.thirdgen.org/forums/v6/2...er#post1862942
https://www.thirdgen.org/forums/tpi/...ighlight=water
https://www.thirdgen.org/forums/tech...er#post1925449
Old Nov 15, 2007 | 04:59 PM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
The who now?
Old Nov 15, 2007 | 05:29 PM
royslsbry's Avatar
Car: 1992 RS
Transmission: 700r
best way to clean everything is disassemble and scrub with a tooth brush
Old Nov 15, 2007 | 05:31 PM
luvofjah's Avatar
"NO DISASSEMBLE!!!"
As Seen on Movie... Short Circuit
Raf
Old Nov 26, 2007 | 03:12 PM
RodsRideSS's Avatar
Car: 87 Monte Carlo SS
Engine: Tweaked out 350
Transmission: tweaked 200r4
yes ..I've been doing it for years. The only thing that I needed to do is remove and clean the EGR...since the carbon will get into it and cause problems. I had a 1984 302 CFI Mercury Cougar with 400,000km ...ran great!!
And yes...be careful of the CAT!
toronto formula
Nov 10, 2015 06:17 AM
lakeffect2
Aug 23, 2015 08:44 AM
Zachattack0925
Aug 12, 2015 09:52 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
