what do you think of these plugs
Old Nov 16, 2007 | 05:40 PM
heavy_chevy29's Avatar
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
i just put these in last week. i only have 2 passes on them. im trying to figure out how the engine is running. i know its running rich at idle thats why one has alittle moist spot. this is only 2 of the 8 plugs. they all look about the same. just let me know what you think. thanks alot
http://s54.photobucket.com/albums/g105/heavy_chevy29/
Old Nov 16, 2007 | 06:42 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: what do you think of these plugs
Your not going to see much after you let it idle. To get anything useful. You have to try to shut down immediatly after WOT. Otherwise, they just tell you how the motor was running when it was idling.
Old Nov 16, 2007 | 10:42 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Which plugs are they? Just looking at the heat range they look WAY too hot. I'd think about stepping down 3 heat ranges or so.
Old Nov 16, 2007 | 11:18 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
off topic, but how's that 700 holding up to all that power? you go with a raptor or a probuilt or something?
just curious...
Old Nov 17, 2007 | 12:46 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I can't tell anything from those photos other than the porcelain is too white looking like it's running too lean. Read these.
http://www.centuryperformance.com/spark.asp
http://www.4secondsflat.com/Spark_plug_reading.html
http://www.dragstuff.com/techarticle...-pictures.html
http://www.dragstuff.com/techarticle...ead-plugs.html
A spark plug can tell you many things if you know what to look for. There's more than just what the insulator looks like. Best rule of thumb for heat range is to run the coldest plug possible that doesn't foul up. Timing and jetting affect the temperature of the plug.
Plugs are cheap. Don't get hung up on fancy expensive plugs. A regular AC Delco plug works just fine. I use NGK race plug in my car. They're less than $3 each. I have a bunch of sets in different heat ranges and all indexed for specific cylinders making a plug swap take less time. I originally had -7 plugs which is a normal heat range. I now use -9 plugs which is 2 heat ranges colder and they still don't foul up. I may have to pick up some -10's.
Old Nov 17, 2007 | 08:03 AM
Car: 84 camaro Z28
Engine: 434sbc
thanks alot for all the replies.
im using delco plugs(i dont know what number of the top of my head). when i bought the motor they had ngks in it. i personally like delcos the best so i went to the parts store and had the cross the ngk numbers to the delcos that i have now.
Stephen 87 IROC:
thanks for the links. i just looked through them real quick. looks like alot of real good info.
Tobias05:
the 700r4 is holding up pretty good. i bought the kit from dana at probuilt and built it myself. lately ive i have been racing it alot(more than ive been driving it on the street). im going to see hold it holds up next season but im most likely going to swap it out for a built th350 with a trans brake.
the reason that im asking about my plugs is because ive been at the track with the car every weekend for about 2-3 month and the car isnt running what it should be. it seems to be falling short up top. if i up the jets in the secondaries, i see not change(better or worse). so i have a feeling that its losing fuel pressure in higher rpms. so now that the tracks are closed i can do some work to the car. im running factory fuel lines and a holley mechanical fuel pump. i dont think that thats going to cut it. so over the winter im going to upgrade to an electric fuel pump with a regulator and bigger lines. once im done with that im going to bring it to a place by my house that does dyno tuning and going to tune it with A/F ratio meter.
Old Nov 17, 2007 | 12:18 PM
Car: 88 Camaro SC
Engine: SFI'd 350
Have you considered just purchasing a hand-held wideband? Its not the be all end all by itself, but along with everything else, it provides an additional piece of information that can help shorten the time needed to tune the motor.
Old Nov 17, 2007 | 06:36 PM
Car: 84 camaro Z28
Engine: 434sbc
yeah i have. im looking at the one from inovative motorsports. i heard really good things about them
Old Nov 17, 2007 | 07:40 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
The megasquirt guys swear by them, mainly because inovative has been really helpful to the community and the product is awesome.
wigmobile
Feb 26, 2025 02:56 PM
gta892000
Aug 11, 2019 11:16 AM
92rsvortec350
Sep 10, 2015 10:54 AM
Jlanz55
Sep 9, 2015 09:09 AM
89 formula TPI
Sep 7, 2015 11:06 AM
